surface film thickness visualisation
Old   September 3, 2020, 15:23
Default surface film thickness visualisation
Riddhideep Biswas
Rid@foam is on a distinguished road
Hello foamers. I am working on sprayFoam and I have started working on surface film modeling and droplet impingement interaction with the film.
Please tell me what I have to do (what options/data/filters I have to apply) in order to visualise the surface film thickness as shown in figure 4. b. (the right hand side figure) of the image that I have attached below in paraview.
Rid@foam is offline   Reply With Quote
Old   September 3, 2020, 17:19
clapointe is on a distinguished road
Checking out one of the film models (e.g. kinematic single layer, https://github.com/OpenFOAM/OpenFOAM...cSingleLayer.H), we see :
//- Film thickness [m]
            volScalarField delta_;
So delta should get you want you're looking for. You can find a description of other fields in that file as well.
Caelan
clapointe is offline   Reply With Quote
Old   September 4, 2020, 14:05
Riddhideep Biswas
Thank you Caelan sir very much for your reply. Now I understand what film thickness is.
But my question is how can I visualise the film in paraview the exact same way as shown in my previous attached figure.
I have converted the film region to VTK and opened it in paraview but I only get a contour visualisation of the thickness (like the figure attached below). What extra filters/data I have to apply to get the physical visualisation of the film as given in my previous attached figure.
Old   September 4, 2020, 14:13
I am not familiar with that image (or what paper it came from) so it is hard to say. However, you can load the film region into paraview (e.g. with paraFoam -region filmRegion) and then experiment with different filters. If I had to guess the film region was clipped to some value and the resulting surface was then colored by delta.
Caelan
paraview, postprocessing; openfoam;, surface film thickness
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
Water film thickness measurement over the cylinder Prudviraj FLUENT 42 May 2, 2020 23:50
surface film in reactingParcelFilmFoam aee OpenFOAM Running, Solving & CFD 10 February 1, 2019 17:29
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 02:44
film thickness using cell wall distance RAHULME FLUENT 0 June 27, 2011 08:25
