How to obtain the wavefront velocity in dam break |
August 24, 2020, 10:28 |
Shilong. Liu
Rep Power: 9 |
Hi everyone,
May I ask how can I get the wavefront velocity in dam-break case? In the velocity contour, I can see the velocity distribution, but how can I get the exact velocity in the wavefront? I searched this, but could not find the accurate solution. Thank you! |
August 24, 2020, 16:20 |
Pablo Higuera
Rep Power: 19 |
Hi Shilong,
just do a contour filter with alpha.water = 0.5 and export the data ("Save data") for all the timesteps in txt or your preferred format. Now you can import and play with it in any data processing program. Best, Pablo |
August 25, 2020, 10:07 |
#3 | |
Shilong. Liu
Rep Power: 9 |
Thank you very much for your suggestion! I will try this method to see the performance. Thank you again! Cheers Shilong |
dam-reak, wavefront velocity |
dam break problem | Mary | CFX | 4 | June 1, 2013 12:50 |
3D dam break modeling(earthen dam) | yasharif | FLUENT | 0 | December 11, 2011 01:25 |
Boundary Conditions in Gambit for a dam break model | Lindsey | FLUENT | 2 | October 5, 2009 02:53 |
obtain non-uniform velocity profile | Atit Koonsrisuk | CFX | 6 | July 9, 2007 06:04 |
Dam break // wet bed | Mehdi BEN ELHADJ | Phoenics | 0 | August 23, 2000 12:47 |
