wind profile inlet setup at openFoam
Old   July 24, 2020, 01:05
Default wind profile inlet setup at openFoam
Hui Zhang
Isaiah_HZ is on a distinguished road
Hi FOAMers,
Recently, I have been working on setting wind profile on inlet boundary, but I got a problem. That is, the actual wind profile appearing at paraFoam is not what I set by use of .csv file.
First file is my 0/U file
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedProfile;
profile csvFile;
profileCoeffs
nHeaderLine 0;
refColumn 0;
componentColumns (1 2 3);
separator ",";
mergeSeparators 0;
file "Uprofile.csv";
direction (0 1 0);
origin 0;
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (0 0 0);
upperWall
type noSlip;
lowerWall
type noSlip;
frontAndBack
type empty;
second is my blockMeshDict
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0)
(100 0 0)
(100 100 0)
(0 100 0)
(0 0 100)
(100 0 100)
(100 100 100)
(0 100 100)
blocks
hex (0 1 2 3 4 5 6 7) // vertex numbers
(100 100 1) // numbers of cells in each direction
simpleGrading (1 1 1) // cell expansion ratios
edges
boundary
inlet
type patch;
faces
(0 4 7 3)
outlet
type patch;
faces
(1 2 6 5)
upperWall
type wall;
faces
(5 6 7 4)
lowerWall
type wall;
faces
(0 3 2 1)
frontAndBack
type empty;
faces
(0 1 5 4)
(7 6 2 3)
third is my Uprofile.csv
1,4.521512266064,0,0
2,5.74080348822266,0,0
3,6.47518490182702,0,0
4,7.00237489142756,0,0
5,7.4139175417953,0,0
6,7.75153394393653,0,0
7,8.03778195361042,0,0
8,8.28624835323104,0,0
9,8.50575370016267,0,0
10,8.70235004129641,0,0
11,8.88037055420773,0,0
12,9.04302453212799,0,0
13,9.19275530770434,0,0
14,9.33146614031959,0,0
15,9.46066852117348,0,0
16,9.58158282629898,0,0
17,9.69520858664116,0,0
18,9.8023747569822,0,0
19,9.90377644888569,0,0
20,10.0000022788663,0,0
21,10.0915550696701,0,0
22,10.1788677537353,0,0
23,10.2623157542867,0,0
24,10.3422267406645,0,0
25,10.4188883990283,0,0
26,10.4925546840546,0,0
27,10.5634508945819,0,0
28,10.6317778290876,0,0
29,10.6977152141953,0,0
30,10.7614245536784,0,0
31,10.8230515116695,0,0
32,10.8827279185736,0,0
33,10.9405734691686,0,0
34,10.996697167891,0,0
35,11.0511985651711,0,0
36,11.1041688200513,0,0
37,11.1556916175805,0,0
38,11.2058439641673,0,0
39,11.2546968798716,0,0
40,11.3023160032561,0,0
41,11.3487621217236,0,0
42,11.3940916380935,0,0
43,11.4383569823987,0,0
44,11.4816069764453,0,0
45,11.5238871574916,0,0
46,11.5652400664264,0,0
47,11.6057055050204,0,0
48,11.6453207661477,0,0
49,11.6841208403179,0,0
50,11.722138601383,0,0
51,11.7594049738909,0,0
52,11.7959490842187,0,0
53,11.8317983973371,0,0
54,11.8669788408148,0,0
55,11.9015149174647,0,0
56,11.9354298078593,0,0
57,11.9687454637871,0,0
58,12.0014826935963,0,0
59,12.0336612402554,0,0
60,12.0652998528633,0,0
61,12.0964163522596,0,0
62,12.1270276913074,0,0
63,12.1571500103615,0,0
64,12.186798688375,0,0
65,12.2159883900497,0,0
66,12.2447331093923,0,0
67,12.2730462100005,0,0
68,12.3009404623686,0,0
69,12.3284280784738,0,0
70,12.3555207438783,0,0
71,12.3822296475565,0,0
72,12.40856550964,0,0
73,12.4345386072511,0,0
74,12.4601587985812,0,0
75,12.4854355453556,0,0
76,12.5103779338121,0,0
77,12.5349946943096,0,0
78,12.5592942196744,0,0
79,12.5832845823782,0,0
80,12.6069735506375,0,0
81,12.6303686035141,0,0
82,12.6534769450902,0,0
83,12.6763055177857,0,0
84,12.6988610148782,0,0
85,12.7211498922841,0,0
86,12.7431783796502,0,0
87,12.7649524908063,0,0
88,12.7864780336198,0,0
89,12.807760619295,0,0
90,12.8288056711531,0,0
91,12.8496184329277,0,0
92,12.8702039766075,0,0
93,12.8905672098554,0,0
94,12.9107128830314,0,0
95,12.930645595844,0,0
96,12.9503698036541,0,0
97,12.9698898234523,0,0
98,12.9892098395301,0,0
99,13.0083339088637,0,0
with those setup, I generated mesh and view mesh. when I plot velocity of inlet boundary condition, the velocity ranged from 2.26 to 13m/s instead of 0 to 13 m/s(please see attached pic). Can anyone help me explain it? Thank you very much!!!!!
Isaiah_HZ is offline   Reply With Quote
Old   July 25, 2020, 01:05
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
I think you visualized the face center values.
A default interpolation scheme(linear) was used and you got (0 + 4.521512266064)/2=2.26.
So, I think the boundary condition works as expected.
Hope this helps,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
Old   July 29, 2020, 01:13
Hui Zhang
Originally Posted by fumiya View Post
Hope this helps,
Fumiya
Thank you for your explanation.
However, when I checked velocity at different locations, they are different from what I have assigned. Do you have this problem before? Fumiya.
Hui
Old   August 1, 2020, 21:31
fumiya's Avatar
Fumiya Nozaki
Unfortunately, I've not used this boundary condition.
So, we need more information on what you wrote.
Best regards,
Fumiya
[Personal]
Old   August 2, 2020, 21:23
Hui Zhang
Best regards,
Fumiya
Fumiya,
It would be very appreciated if you can provide some materials or links about this kind of boundary condition.
Best,
Hui
Old   August 3, 2020, 12:22
ssa
ssa_cfd is on a distinguished road
Did you try adding more points between 0 and 1 ?
Check the number of cells between 0 and 1 meters in paraview and add more points in the UProfile.csv
0,0,0,0
0.1,x,x,x
0.2,x,x,x
I think it is just an interpolation problem.
ssa_cfd is offline   Reply With Quote
Old   August 3, 2020, 12:31
Hui Zhang
0,0,0,0
0.1,x,x,x
0.2,x,x,x
Thank you, Ssa!
I will try! When I got any results, I will let you know and then we can talk about it.
Best,
Hui
inlet bc; wind profile;
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
Validating wind profile with atmBoundaryLayer greenteam OpenFOAM Running, Solving & CFD 1 September 23, 2018 20:34
help with boundary profile in pressure inlet quiqui FLUENT 21 June 18, 2013 13:55
NON-UNIFORM VELOCITY INLET BOUNDARY PROFILE MURAT Main CFD Forum 0 December 30, 2003 22:08
create logarithmic wind profile for inlet Murat Main CFD Forum 0 December 30, 2003 01:45
