How to write a script to automatically modify the parameters of 0 / u file for simula
Old   July 18, 2020, 05:23
Smile How to write a script to automatically modify the parameters of 0 / u file for simula
liwenpeng
liwenpeng is on a distinguished road
I need batch script to automate the process.
I may need to do several thousand simulations of flow around a rotating cylinder, the cylinder rotating speed from-100 to 100, the interval is 0.2.
But at present, I adjust the parameters manually every time, and the post-processing is also carried out manually. Forthousands of simulations, it is impossible to realize. Is there anyway and how to automatically adjust parameters and simulate. ?
I can not find any example about bash script,who could give me some example or tutorial about how to write the script.
Do I need python or matlab or shell,I do not know,I am a new with poor programming skill.
my openfoam run in Ubuntu
Many thanks!!
liwenpeng is offline   Reply With Quote
Old   July 23, 2020, 18:45
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You might want to take a look at the following tutorial:
https://develop.openfoam.com/Develop...pleFoam/bump2D
In this tutorial, RAS_MODEL in turbulenceProperties file is replaced to each turbulence model's name by Allrun sh script.
Hope this helps,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
