how to adjust velocity in 0/u file Automatically |
July 17, 2020, 06:30 |
liwenpeng
Rep Power: 6 |
Hi,OPers
I'm new to Openfoam and wondering how to change parameters automatically after a successful run. I have a flow around cylinder case with constant inlet velocity which is simulated with pimpleFoam (in laminar mode). I want to increase the Reynolds number (by changing the inlet velocity after each successful run with the solver and then rerun the solver and I want to find an automatic way to do that. I might have to run thousands of simulations, and manually modifying parameters is terrible ,so I'm wondering how it can be done in Openfoam. many thanks |
July 17, 2020, 11:17 |
Ran
Rep Power: 10 |
If your Reynolds number has a range that covers from 1 to 100000,
it's hard to auto this process. Higer Re means higher grid resolution. People usually do discretized runs. In other words, set up cases in advance. Then run those simulations independently.
Yours in CFD, Ran |
July 17, 2020, 23:48 |
liwenpeng
Rep Power: 6 |
the Reynold number will not larger than 5000.Did I need a pyfoam or install matlab in linux system to to run thousands of simulations automatically?
July 18, 2020, 06:20 |
Rep Power: 12 |
For changing velocity you can use uniformFixedvalue with tabulated input..
e.g. Iteration velocity 0 1 1000 10 2000 20 And so on. |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 17:05 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 19:13 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
