Regarding error in new expression syntax in openfoam 1912
Old   July 15, 2020, 13:02
Default Regarding error in new expression syntax in openfoam 1912
ijaz fazil
er_ijaz is on a distinguished road
Hi I need to model variable flow rate with time depending on the temperature on the particular patch.
If Temp<300.15 K then flow rate is 0.058;
else Temp>300.15K then flow rate is (m*temp)+c
I recently read that expressions can be modelled directly in openfoam 1912.
Initially I tried to model flowrate I'm unable to do so. Hence I used
SERVER_SOURCE
type exprFixedValue;
value $internalField;
valueExpr "(tSink<=300.15)?vector(0,value1/area1,0):vector(0,((0.00531*tSink)-0.08485)/area1,0)";
variables
"tSink{SERVER_SINK} = weightAverage(T)"
"value1{SERVER_SOURCE} = 0.05852"
"area1{SERVER_SOURCE} = area()"
But Im getting the following warning while the simulation is running
"--> FOAM Warning :
From function bool Foam::expressions::exprResult::getUniformChecked(F oam::expressions::exprResult&, Foam::label, bool, bool) const [with Type = double; Foam::label = int]
in file expressions/exprResult/exprResultI.H at line 143
Different min/max values: (0.000674827 0.00410428) Using the average 0.00146216
Can any one explain how to fix this error?
er_ijaz is offline   Reply With Quote
Old   July 15, 2020, 13:09
Default updated information
ijaz fazil
for information I changed the expression as below
valueExpr "(tSink<=300.15)?vector(0,value2/area2,0):vector(0,((0.00531*tSink)-0.08485)/area2,0)";
variables
"value2 = 0.05852"
"area2 = 0.20025"
The simulation is running fine but still I'm not sure what is the cause of the warning.
openfoam1912, pyfoam, pyfoam tutorial error, swak4foam, swak4foam error
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
OpenFOAM Training Beijing 22-26 Aug 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 May 3, 2016 05:57
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
Expression and Syntax for PDEs JD CFX 2 January 3, 2010 05:19
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 18:23
