July 15, 2020, 10:43 |
Helyx-OS Thermal Solution Help
Dakota
I am a recent mechanical engineering graduate from trying to learn Helyx through the open source product to determine if I would like to use it in the future for consulting work. I set up a flow analysis of two flows into one for a simple learning point of the software and I managed to get both inputs flowing and able to output information correctly. The problem is when I try to just add thermal energy the solver is no longer able to run correctly. I get met with this message in the terminal, then nothing happens: Code:
Solver : buoyantBoussinesqSimpleFoam The buoyantBoussinesqSimpleFoam solver has been replaced by the more general buoyantSimpleFoam solver
I am using Ubuntu 19.10 with 32 gb of memory and an i9 processor. The HelyxOS version I am using is v2.4.0. If there is any more information I can provide you, please let me know. Edit: I am trying to attached a zip folder of my documents, but it is not letting me. I am being met with this message: Your submission could not be processed because a security token was missing. If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error. |
beginners, helyxos 2.0, openfoam |
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
Filtering DNS solutions Vs projecting filtered DNS solution | juliom | Main CFD Forum | 5 | May 19, 2016 17:06 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 08:51 |
Anistropic thermal conduction in Fluent 6.2 | Bharath | FLUENT | 0 | November 23, 2006 22:07 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
