How to accessing field value from other patches with respect to time in openfoam1912?
Old   July 5, 2020, 08:02
Default How to accessing field value from other patches with respect to time in openfoam1912?
ijaz fazil
er_ijaz is on a distinguished road
Hi
I noticed that in openfoam 1912, Integration of swak4Foam Functionalities
So in case if I need to add expression no need to install swak4foam seperately.
2) I need to update supply value from one patch based on the results of another patch with respect to time. I wish to know whether it can be performed using "expression"
er_ijaz is offline   Reply With Quote
Old   July 22, 2020, 22:28
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You might want to check if the expressions described in the following link can be used with v1912:
https://www.openfoam.com/documentati...on-syntax.html
Hope this helps,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
expression, groovybc, openfoam1912, pyfoam, swak4foam
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 01:58
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
