ddt for unsteady term
Old   July 5, 2020, 02:19
Default ddt for unsteady term
Jagan Mohan
jagan1mohan is on a distinguished road
Hello Friends, I'm trying to build an application in OpenFOAM. I'm starting from scratch as I think this is best way to learn what exactly happens behind screen. Lets focus on following.
for (int i = 0; i <= 10; i++)
solve
fvm::laplacian(kTh, T)
runTime++;
runTime.write( );
This code runs okay and I get the required temperature profile. Next, I experimented following code, with all others details implemented into main function, compilation successful, here are my questions.
solve
fvm::ddt(T) - konst
runTime++;
runTime.write( );
As you can see, I'm solving a first order linear differential equation in T. I have casted konst as dimensionedScalar and everything compiles without any error. ControlDict settings are timeStep is 1 with some startTime and endTime. What I observe is in all steps, the initial, final residual and iterations are perfect 0. That is, equation is not being solved.
1. What is happening here?
2. How to make this solve? We should expect a linear increase in temperature by 1 unit in very time step across all the domain.
Thank you,
Jagan Mohan.
jagan1mohan is offline   Reply With Quote
How to add Source term (2) for PYROLYSIS - reactingOneDim Kummi OpenFOAM 10 April 12, 2021 22:11
Source term for EVAPORATION in Energy Equ. - technical difficulty ? Kummi OpenFOAM 1 September 9, 2019 10:32
rhoPimpleFoam - ddt term upadhyay.1 OpenFOAM Running, Solving & CFD 0 October 18, 2017 09:44
How does fluent discretize the viscous term? motorbean FLUENT 3 August 25, 2015 17:38
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
