June 28, 2020, 13:48 |
swak4foam installation in openfoam
VSUM
Rep Power: 6 |
Hello everyone,
I was trying to install swak4foam in openfoam. Currently i have the openfoam-dev version installed. Later after Google searching and from cfd-online i felt that in only certain specific versions of openfoam, different versions of swak4foam can be installed without the compilation errors. I also found that openfoam v1912 from ESI may have in-built swak4foam into it. But still searching for it, i could locate any resources online that says so about it. So, i was wondering if you could provide suggestions for installing swak4foam and pyfoam in the most suitable version of openfoam. Thank you for your time. |
June 29, 2020, 11:21 |
Suggestions
Collin
Rep Power: 6 |
Have you tried looking into these links?
https://openfoamwiki.net/index.php/I...opment_version https://openfoamwiki.net/index.php/Contrib/swak4Foam |
June 29, 2020, 11:48 |
VSUM
Rep Power: 6 |
Yes... I did look at those web pages. I found that foamextend 4.0 goes well with swak4foam. But in one of the cfd-online threads, i saw that there might be some convergence issues with foamextend versions. So...i was curious if openfoam v7 or openfoam v1912...or other any other version was more stable and easy to work with swak4foam.
Anyways thanks for replying. |
June 29, 2020, 18:20 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
June 29, 2020, 18:33 |
VSUM
Rep Power: 6 |
Thanks for the info... Will certainly look into that.
openfoam, pyfoam, swak4foam |
[swak4Foam] Swak4FOAM installation for OpenFOAM v1806 | exx110 | OpenFOAM Community Contributions | 1 | July 5, 2021 20:07 |
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM | steven123 | OpenFOAM Community Contributions | 35 | January 11, 2021 16:53 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
[Discussion] Restructuring the Installation page at openfoamwiki.net | wyldckat | OpenFOAM Installation | 16 | November 2, 2013 11:43 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
