Boundary codition of pointDisplacement at the immersed boundary?? |
Chaewoong Ban
Rep Power: 13 ![]() |
Hello.
I'm now struggling to find the adequate boundary conditon for the pointDisplacment at the immersed boundary. pointDisplacement is pointVectorField, and I guess there is no proper BC for pointVectorField in the implemented IB method (foam-extend 4.1). In that case, I may have to implement some BC for pointVectorField..? Could you give me any comments or hints for this? Many thanks. |
Rep Power: 8 ![]() |
is there a typo in zeroGradientIB?
i mean, did you mean just zeroGradient? |
#3 | |
Chaewoong Ban
When I use zeroGradientIB, the result is the same as above. As you can see in the picture (right), FOAM recommended 24 patchField type, which have nothing to do with IB. When I use zeroGradient, then simulation move next step. However, another error occur (below). I think it is related with that the zeroGradient BC is not proper for the IB. ---------------------------------------------------------------------------------------------------------------------- --> FOAM FATAL ERROR: Not implemented From function immersedBoundary::gradientInternalCoeffs() in file lnInclude/fvPatchField.H at line 473. FOAM aborting Aborted (core dumped) ---------------------------------------------------------------------------------------------------------------------- |
Chaewoong Ban
I use motionU instead of pointDisplacement for the dynamic mesh motion.
In addition, I made(link?) a boundary condition of tetPointVectorField for the immersedBoundary. eddited class /foam /tetFiniteElement |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
