June 25, 2020, 08:50 |
Modelling dust particles in air
NewtonianGuy
Rep Power: 6 |
Hi everyone!
I am very new on OpenFOAM. I would like to model dust deposition on a surface (lets say PV panel). I saw that there is a variety of models that adress multiphase modelling. Is openFoam capable of doing that? What type of models : euler / lagrangian ? and solvers? Is it easy to model with a particle size distribution? and last if there is some references with similar projects on Openfoam, it would be great ! Thank you |
June 25, 2020, 09:22 |
Rep Power: 8 |
you can use multiphaseEulerFoam.
multiple disperse phases with individual corn sizes for each phase. with the lagrange approach, you won't be able to simulate volume fraction > 10 %. there is the limitation. |
June 25, 2020, 17:20 |
Utkan Caliskan
Rep Power: 12 |
You can simulate it quite well using the MP-PIC which is an Eulerian-Lagrangian approach. There is no limitation in this approach with respect to solids ratio. I believe it's better approach than an EulerFoam solver for your case, especially for the particle size distribution.
multiphase, openfoam |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Modelling air cooling of an engine | KToMmi | FLUENT | 1 | June 27, 2018 15:13 |
Water Sphere reacting to flow of air modelling | Jacee | FLUENT | 0 | May 25, 2018 09:29 |
Modelling an air filter | siw | CFX | 5 | September 13, 2011 12:48 |
air core modelling using fluent | asifmohammad7 | FLUENT | 3 | April 5, 2011 20:38 |
