June 23, 2020, 06:03 |
snappyHexMesh segmentation fault
NewtonianGuy
Rep Power: 6 |
Hi everyone!
I Am currently trying to model a flow over an airfoil. For that I created a BlockMesh base and i am trying to use snappyhexmesh to enter my geometry in the mesh. Everytime I try to run snappyhexmesh i get a segmentation fault (core dumped). I am new in OpenFoam and i would appreciate any help. I have attached my snappyHexMeshDict, blockmeshDict and .stl file. Here is also the error message : Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-3bcbaf946ae9 Exec : snappyHexMesh Date : Jun 23 2020 Time : 11:16:22 Host : "cheikhna" PID : 13290 I/O : uncollated Case : /home/cheikhna/OpenFOAM/cheikhna-7/run/airFoil2D nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Read mesh in = 0.11 s Overall mesh bounding box : (0 0 -1) (110 20 1) Relative tolerance : 1e-06 Absolute matching distance : 0.000111821 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 STLLexer::lex() at ??:? #4 Foam::triSurface::readSTLASCII(Foam::fileName const&) at ??:? #5 Foam::triSurface::readSTL(Foam::fileName const&) at ??:? #6 Foam::triSurface::read(Foam::fileName const&, Foam::word const&, bool) at triSurface.C:? #7 Foam::triSurface::triSurface(Foam::fileName const&) at ??:? #8 Foam::triSurfaceMesh::triSurfaceMesh(Foam::IOobject const&, Foam::dictionary const&) at ??:? #9 Foam::searchableSurface::adddictConstructorToTable<Foam::triSurfaceMesh>::New(Foam::IOobject const&, Foam::dictionary const&) at ??:? #10 Foam::searchableSurface::New(Foam::word const&, Foam::IOobject const&, Foam::dictionary const&) at ??:? #11 Foam::searchableSurfaces::searchableSurfaces(Foam::IOobject const&, Foam::dictionary const&, bool) at ??:? #12 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/snappyHexMesh" #13 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #14 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/snappyHexMesh" Segmentation fault (core dumped) Tell me if I need to submit any additional files. Thank you |
June 23, 2020, 09:41 |
Rep Power: 10 |
I would believe the segmentation fault may be a "red herring" in your debugging process. Let fix the location in mesh part first.
1. Assuming you want to simulate flow external to the geometry. The location in mesh should be a point within the rectangle, but it should NOT be within the airfoil geometry. 2. For shm to know where the airfoil stl is, use the geometry sub dictionary inside of shm. It is in the top of the file. Also remember that shm only looks For STL files located in the case/constant/triSurface directory. |
June 25, 2020, 03:49 |
NewtonianGuy
Rep Power: 6 |
Thank you for your advice! I finally managed to find my problem. I believe it was the STL file taken out from solidworks. It was in binary and not in ASCII, I did the conversion using the surfaceConvert from OpenFoam.
Regarding the location in Mesh, it is simply the coordinates of my blockmesh that I can shift (vertices), or shit my geometry in solidworks with respect to the frame. |
June 25, 2020, 08:25 |
#4 | |
Rep Power: 10 |
June 25, 2020, 08:41 |
NewtonianGuy
Rep Power: 6 |
Sorry...
I meant that I found a way to place my geometry in my base Mesh (generated through blockMesh). I though first that snappyHexMesh can place my geometry in a disered place but it doesnt (correct me if i am wrong). So basically, I just changed the coordinates of my base mesh to have my airfoil in the center for example. |
June 25, 2020, 12:36 |
Rep Power: 10 |
Your are correct.
SnappyHexMesh does not move surface file to the background mesh Open foam does have the "surfaceTransformPoints" function, which can be used to move, scale, and rotate surfaces. https://www.openfoam.com/documentati...ormPoints.html |
openfoam, segmentation fault, snappy hex mesh |
snappyHexMesh in parallel leads to segmentation fault | ChrisHa | OpenFOAM Pre-Processing | 1 | January 14, 2019 10:04 |
[snappyHexMesh] SnappyHexMesh multioprocessor run causes segmentation fault | MarcusNHofer | OpenFOAM Meshing & Mesh Conversion | 5 | June 11, 2015 08:06 |
[snappyHexMesh] snappyHexMesh Segmentation Fault | avd28 | OpenFOAM Meshing & Mesh Conversion | 11 | May 11, 2015 20:32 |
[snappyHexMesh] SnappyHexMesh segmentation Fault | nithishgupta | OpenFOAM Meshing & Mesh Conversion | 1 | December 18, 2014 04:03 |
segmentation fault when installing OF-2.1.1 on a cluster | Rebecca513 | OpenFOAM Installation | 9 | July 31, 2012 15:06 |
