How to implement reconCentral in Openfoam1812
Like Tree1Likes
Old   June 22, 2020, 05:10
Default How to implement reconCentral in Openfoam1812
hbulus is on a distinguished road
I tried to implement a limitedscheme reconCentral from foam extend 4.0 (foam40/src/finiteVolume/interpolation/surfaceInterpolation/limitedScheme) to openFoam v1812. But when i tried to compile the code i get this error :
Making dependency list for source file reconCentral.C
g++ -std=c++11 -m64 -DOPENFOAM=1812 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100 -I/opt/apps/OpenFOAM/OpenFOAM-v1812/src/finiteVolume/lnInclude -I/opt/apps/OpenFOAM/OpenFOAM-v1812/src/meshTools/lnInclude -IlnInclude -I. -I/opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude -I/opt/apps/OpenFOAM/OpenFOAM-v1812/src/OSspecific/POSIX/lnInclude   -fPIC -c reconCentral.C -o Make/linux64GccDPInt32Opt/reconCentral.o
reconCentral.C: In member function âvirtual Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::reconCentral<Type>::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) constâ:
reconCentral.C:97:15: error: âunallocLabelListâ does not name a type
         const unallocLabelList& pOwner = p.faceCells();
In file included from /opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/UList.H:51:0,
                 from /opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/List.H:43,
                 from /opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/wordList.H:48,
                 from /opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/Enum.H:40,
                 from /opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/IOobject.H:79,
                 from /opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/regIOobject.H:41,
                 from /opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/GeometricField.H:42,
                 from /opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/GeometricScalarField.H:38,
                 from /opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/GeometricFields.H:34,
                 from /opt/apps/OpenFOAM/OpenFOAM-v1812/src/finiteVolume/lnInclude/volFields.H:37,
                 from reconCentral.C:25:
reconCentral.C:114:20: error: âpOwnerâ was not declared in this scope
             forAll(pOwner, facei)
/opt/apps/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/stdFoam.H:285:30: note: in definition of macro âforAllâ
     for (Foam::label i=0; i<(list).size(); ++i)
reconCentral.C:143:20: error: âpOwnerâ was not declared in this scope
reconCentral.C: In instantiation of âFoam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::reconCentral<Type>::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) const [with Type = Foam::Vector<double>]â:
reconCentral.C:200:1:   required from here
reconCentral.C:58:64: error: invalid initialization of reference of type âFoam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>&â from expression of type âconst Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>â
     GeometricField<Type, fvsPatchField, surfaceMesh>& sf = tsf();
reconCentral.C:74:42: error: invalid initialization of reference of type âFoam::Field<Foam::Vector<double> >&â from expression of type âconst Internal {aka const Foam::DimensionedField<Foam::Vector<double>, Foam::surfaceMesh>}â
     Field<Type>& sfIn = sf.internalField();
reconCentral.C:89:33: error: no type named âGeometricBoundaryFieldâ in âclass Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>â
         GeometricBoundaryField& bSf = sf.boundaryField();
reconCentral.C: In instantiation of âFoam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::reconCentral<Type>::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) const [with Type = double]â:
reconCentral.C:58:64: error: invalid initialization of reference of type âFoam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&â from expression of type âconst Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>â
reconCentral.C:74:42: error: invalid initialization of reference of type âFoam::Field<double>&â from expression of type âconst Internal {aka const Foam::DimensionedField<double, Foam::surfaceMesh>}â
reconCentral.C:89:33: error: no type named âGeometricBoundaryFieldâ in âclass Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>â
make: *** [Make/linux64GccDPInt32Opt/reconCentral.o] Error 1
I know how to imply an own solver, but an utility scheme i dont know. Any help will be very helpful.
Thanks for every response !
hbulus is offline   Reply With Quote
Old   June 22, 2020, 07:18
geth03 is on a distinguished road
read the error code:
obviously, openfoam v1812 doesn't recognize unallocLabelList.
replace it with labelUList&.
geth03 is offline   Reply With Quote
Old   June 22, 2020, 10:31
Thanks for your response, i fixed some of the wrong parts, thanks to you!
But now, i got the error at the below. Since i dont know c++, i cant figure out. Could you help me with this too ?
Error message :
wmakeLnInclude: linking include files to ./lnInclude
In file included from reconCentral.C:25:0:
reconCentral.H:149:73: error: expected â;â at end of member declaration
         interpolate(const GeometricField<Type, fvPatchField, volMesh>&) const
reconCentral.C:36:1: error: prototype for âFoam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::reconCentral<Type>::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)â does not match any in class âFoam::reconCentral<Type>â
reconCentral.H:149:9: error: candidate is: virtual Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::reconCentral<Type>::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) const
the related part in .H
// Member Functions
        //- Return the face-interpolate of the given cell field
        //  with explicit correction
        virtual tmp<GeometricField<Type, fvsPatchField, surfaceMesh>>
        //- Return true if this scheme uses an explicit correction
        virtual bool corrected() const
            return true;
        //- Return the explicit correction to the face-interpolate
        correction
            const GeometricField<Type, fvPatchField, volMesh>& vf
        ) const;
the related part in .C
template<class Type>
Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh>>
Old   June 23, 2020, 06:24
related part in .H:
// Member Functions
        interpolate(const GeometricField<Type, fvPatchField, volMesh>&) const;
            return true;
        correction
        ) const;
there is a ";"-sign missing after const for your first template function.
please check the code above.
Old   June 24, 2020, 04:19
Originally Posted by geth03 View Post
related part in .H:
// Member Functions
            return true;
        correction
        ) const;
Thanks for your quick response, i added ";" sign of course
What i was trying to say , Do you see anything that makes no sense in C++ because it is still not compiled. I attached the .C and .H files if you might check.
Old   June 24, 2020, 05:44
i can't really judge if everything is ok, bc openFOAM is a really large library and i don't know each class and function.
when i try to modify something in OF, i usually try to fix every error code output in the terminal. it can be really time consuming.
in your case, you try to implement something from OF extend to OF v1812. as you already posted earlier, there was a class in the extend version which was named differently in v1812. so it would be wise if you would follow each error output and fix everything step by step instead of looking at each code line.
why does it not compile? is there any error-message?
what is the terminal output?
Old   June 24, 2020, 07:19
Yeap you are right. Some classes have been changed, it is not easy to know every of them. Maybe Prof Jasak the only person who knows.
Here is what the terminal gave :
reconCentral.H:150:9: error: candidate is: virtual Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::reconCentral<Type>::interpolate(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) const
Old   June 25, 2020, 04:02
your .H-file lines 149-150:
your .C-file lines 34-42:
Foam::tmp<Foam::reconCentral<Type>>
//Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh>>
Foam::reconCentral<Type>::New
    const GeometricField<Type, fvPatchField, surfaceMesh>&,
in your .C-file you define something different than you declare in your .H-file.
the correct substitution should be:
) const
there is a mismatch, you don't define in your .C-file what you declared in your .H-file. If you want to implement the function you declared in your .H-file, you need to define it properly and accordingly.
Old   June 25, 2020, 09:17
) const
I fixed the .C code later, but i uploaded the wrong one here. The output that i gave in my previos post, was gotten in form of the code as you said. You can try though. Sorry for misleading
Old   June 26, 2020, 06:33
can you please upload your correct .H and .C files.
Old   June 29, 2020, 03:35
Sorry for late return. Here it goes, thanks a lot.
Old   July 1, 2020, 04:51
Does this question really hard that much
Old   July 1, 2020, 10:23
i checked also the original source code and don't really know what the problem is. the code looks fine to me.
Old   July 2, 2020, 09:30
Thanks for your all effort. I gave you repetition point as return .
I really stucked with this problem. Is there anyone who can help?
Thanks for every response!
Old   July 2, 2020, 09:52
ok, lets try one more time
your .C-File from line 34 onwards:
//Foam::tmp<Foam::reconCentral<Type>>
//Foam::reconCentral<Type>::New
  //  const GeometricField<Type, fvPatchField, surfaceMesh>&,
   // const tmp<surfaceScalarField>& tsf,
   // const tmp<surfaceScalarField>& pSf
)  const //adjust this
    //code ...
Old   July 3, 2020, 02:33
    //code ...
Nope, it didn't work
Were you be succesful with this change ?
Old   July 3, 2020, 03:32
i just checked the code once more and saw that this part was missing
Old   November 25, 2020, 02:41
Is there any code developer for Foam Extend or OpenFoam to help this little but hard problem for me?
Old   November 25, 2020, 13:25
clapointe is on a distinguished road
A long time ago I ported the limiter to Openfoam 7. I don't know how this compares to v1812, but it may be closer than foam-extend.
Caelan
hbulus likes this.
clapointe is offline   Reply With Quote
Old   November 27, 2020, 04:15
Thanks a lot, i can make some modification from your codes, then it compiled. I wmake in src/finiteVolume/interpolation/limitedSchemes as reconCentral file with required Make files. However, when i try to run with this fvSchemes, it says Unknown discretisation scheme reconCentral :
ddtSchemes
default steadyState;
gradSchemes
default cellLimited leastSquares 1.0;
divSchemes
default none;
div(phi,U) Gauss reconCentral cellLimited leastSquares 1.0;
div(phi,k) Gauss vanLeerDC;
div(phi,omega) Gauss vanLeerDC;
div(R) Gauss linear;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear limited 0.5;
laplacian((1|A(U)),p) Gauss linear limited 0.5;
laplacian(DkEff,k) Gauss linear limited 0.5;
laplacian(DomegaEff,omega) Gauss linear limited 0.5;
laplacian(1,p) Gauss linear corrected;
interpolationSchemes
default reconCentral phi leastSquares;
interpolate(U) reconCentral phi leastSquares;
snGradSchemes
default limited 0.5;
fluxRequired
default no;
p ;
Do you have any idea why it gives this error ?
EDIT I solved the problem, you have to add libs("linreconCentral.so") at the bottom of controlDict file because i did not compile at top level of src.
How to implement a rigid lid aproximation for a 2d flow? Jaydi_21 Main CFD Forum 0 August 1, 2018 14:40
Implement swirl as "internal" BC with calculated u_axial lentschi CFX 6 November 2, 2011 05:58
Problems to implement a coordinate change mateusps OpenFOAM 3 September 22, 2011 14:20
How to implement implicit TVD limiter? Kmlin Main CFD Forum 3 March 28, 2010 09:52
how to implement this kind of equation keishawillstone OpenFOAM Running, Solving & CFD 2 August 11, 2009 07:01
