chtMultiregionFoam issues with heat sources
Old   May 1, 2020, 11:46
Unhappy chtMultiregionFoam issues with heat sources
Nicolò Badodi
NBad is on a distinguished road
Hi everyone!
I'm in desperate need of help!
I set up a case in which a cylindrical heating element 2 cm in diameter and 4 cm long is heated with a power of 404 W and irradiates the surroundings.
The heater is surrounded by vacuum (modeled as air with very low kappa and cp, frozen flow), and everything is enclosed in a reradiating furnace wall, except that two stripes of this wall are actually held at 600K and so absorb all the exceding heat.
I used fvDOM as radiation model.
The analytical calculation shows that the heater, which is made of silicon carbide, should heat up at a rate of 52 K/s, while calculation with cht shows a heating of only 8K/s, which is much lower.
The setup can be seen in the image I attached (PS there is a mesh in between the heater and the external wall)
I'll post here the configuration files related to the heating element:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant/heater";
    object      fvOptions;
heatSource
    type            scalarSemiImplicitSource;
    active          true;
    scalarSemiImplicitSourceCoeffs
		selectionMode       all;
        volumeMode      	absolute; //specific;//absolute;
        injectionRateSuSp
			rho (3200 0); //TODO: is this required?
            h (404 0); //TODO: 404 W is this the right unit?
Here I set up a heat source for the heating element
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant/solid";
    object      thermophysicalProperties;
thermoType
    type            heSolidThermo;
    mixture         pureMixture;
    transport       constIso;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleEnthalpy; //sensibleEnthalpy;
mixture
    // Silicon carbide
    specie
        molWeight       1000;
    equationOfState
        rho             3200;//3200; //g/cm2
    transport
        kappa           120;//120; //W/cm*K
    thermodynamics
        Hf              0;
        Cp              190;	//J/(g*K)
And here are the thermophysical properties of the heating element.
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0/solid";
    object      T;
dimensions      [ 0 0 0 1 0 0 0 ];
internalField   uniform 300;
boundaryField
    #includeEtc "caseDicts/setConstraintTypes"
    front_cyc
        type            cyclic;
    back_cyc
        type            cyclic;
    heater_to_air
        type            compressible::turbulentTemperatureRadCoupledMixed;
        value           uniform 300;
        Tnbr            T;
		T				T;
        kappaMethod     solidThermo;
        qrNbr           qr;
        qr              none;
/*		type			zeroGradient;*/
Last but not least the boundary condition file that couples temperature in this solid to radiation in the neighbour solid.
the whole case can be found here:
https://drive.google.com/open?id=1xi...5dn-LkhGKw7QKl
Any idea of what could be causing this issue? Wrong unit in the thermophysical properties? Wrong injection of heat?
Please help!
NBad is offline   Reply With Quote
Old   May 14, 2020, 04:00
Carlos Rubio Abujas
crubio.abujas is on a distinguished road
Hi Nicoló,
I think the heatSource may have different units. The field h is defined inside the source code as solidThermo::he, which have units of [J/kg]. So the rate of change may be [W/kg] if the volumeMode is absolute, as it seems your case. If that is correct and you want the cylinder to provide 404W, you need to set the scalarSemiImplicitSource to be around 5050 W/kg (according to some rough calculations).
That is in the order of the error you mentioned, so may be reasonable to try.
Hopes it helps!
crubio.abujas is offline   Reply With Quote
Old   June 13, 2020, 06:16
Nicolò Badodi
Hi Crubio!
Turns out that the units were right, but there was an error in the fvSolution file, that was making my solver use the PGC algorithm for the solution of the enthalpy equation instead of GAMG.
All solved now!
cfd, chtmulitregionfoam, heat and mass transfer, heat sources, multi region
Two simultaneous heat sources in ANSYS APDL Unkinunki ANSYS 10 May 24, 2021 08:47
OpenFOAM heat sink chtMultiRegionFoam amdk136 OpenFOAM Running, Solving & CFD 1 September 21, 2020 08:07
chtMultiRegionFoam connection between solid and fluid region of heat exchanger ahab OpenFOAM 1 December 18, 2019 01:37
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
