April 11, 2020, 07:42 |
using rhoReactingFoam for 2D DLR scamjet
Yan Chong
I'm A PHD student major in combustion. Recently, I want to simulate a supersonic combustion case using OpenFoam. I thought rhoReactingFoam maybe capable for the case. But the position of the shock wave is ayways incorrect. I thought that may caused by th boundry condition of U or P or something else,but i cant figure is out. can anyon give me some suggestions?
p Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { inletfuel { type fixedValue; value uniform 101325; } inletair { type fixedValue; value uniform 101325; } outlet { type zeroGradient; } frontAndBackPlanes { type empty; } WALL_TOP { type zeroGradient; } WALL_BOT { type zeroGradient; } WALL_INSIDE { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (730 0 0); boundaryField { inletfuel { type fixedValue; value uniform (1200 0 0); } inletair { type fixedValue; value uniform (730 0 0); } outlet { type inletOutlet; inletValue uniform (730 0 0); value uniform (730 0 0); } frontAndBackPlanes { type empty; } WALL_TOP { type fixedValue; value uniform (0 0 0); } WALL_BOT { type fixedValue; value uniform (0 0 0); } WALL_INSIDE { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 1200; boundaryField { inletfuel { type fixedValue; value uniform 250; } inletair { type fixedValue; value uniform 1200; } outlet { type inletOutlet; inletValue uniform 340; value uniform 340; } frontAndBackPlanes { type empty; } WALL_TOP { type zeroGradient; } WALL_BOT { type zeroGradient; } WALL_INSIDE { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss linearUpwindV grad(U); div(phi,Yi) Gauss linearUpwind; div(phi,h) Gauss linearUpwind; div(phi,K) Gauss linearUpwind grad(U); div(phid,p) Gauss linearUpwind; div(phi,omega) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,Yi_h) Gauss upwind; div(phi,k) Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(phiv,p) Gauss linearUpwind grad(U); } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; //interpolate(rho) upwind phi; //interpolate((rho*(1|A(U)))) upwind phi; //flux(HbyA) upwind phi; //dotInterpolate(S,(rho_0*U_0)) linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "rho.*" { solver diagonal; } p { solver PBiCGStab; preconditioner DIC; tolerance 1e-6; relTol 1e-6; } pFinal { $p; relTol 0; } "(U|e|k|epsilon|omega)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-6; relTol 1e-6; } "(U|e|k|epsilon|omega)Final" { $U; } "Yi.*" { solver PBiCGStab; preconditioner DILU; tolerance 1e-8; relTol 1e-6; } } PIMPLE { momentumPredictor yes; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 1; maxDeltaT 1e-7; maxCo 0.25; alphaTemp 0.05; alphaY 0.05; Yref { O2 0.1; H2 0.1; } rDeltaTSmoothingCoeff 0.05; rDeltaTDampingCoeff 1; } relaxationFactors { equations { ".*" 1; } } // ************************************************************************* // |
April 13, 2020, 03:43 |
CHEUNG WING KI
Rep Power: 9 |
I am doing combustion research on this geometry at the moment. You can try the "waveTransmissive" boundary on the p.outlet Regards, Rick |
May 15, 2024, 16:52 |
mustafa
hello. im simulating supersonic air hydrogen mixing in DLR Scramjet combustion too if you solve this problem or not can yol share case file? thank you.
supersonic.combustion |
The pressure equation in reactingFoam and rhoReactingFoam | cryabroad | OpenFOAM Running, Solving & CFD | 14 | January 21, 2024 14:09 |
No way to use DLR in-house code? | spalartallmaras | Main CFD Forum | 2 | November 6, 2019 18:26 |
reactingFoam vs rhoReactingFoam | Scot | OpenFOAM Running, Solving & CFD | 8 | June 2, 2016 12:28 |
Governing Equations of RhoReactingFoam | Sermengi | OpenFOAM Programming & Development | 2 | March 23, 2015 11:24 |
Bug in rhoReactingFoam | francesco_capuano | OpenFOAM Bugs | 2 | February 6, 2012 16:11 |
