Rep Power: 6 ![]() |
Hello everyone.
I have little problem with setup of computing cluster. When I'm trying to install OF on slave branches, it's end up with problem with packages installation (universe repository is enabled). When i tried to Code:
Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: linux-image-generic : Depends: linux-image-4.4.0-176-generic but it is not going to be installed or linux-image-unsigned-4.4.0-176-generic but it is not going to be installed Recommends: thermald but it is not going to be installed linux-modules-extra-4.4.0-176-generic : Depends: linux-image-4.4.0-176-generic but it is not going to be installed or linux-image-unsigned-4.4.0-176-generic but it is not going to be installed openfoam7 : Depends: libreadline-dev but it is not going to be installed Depends: libboost-thread1.58.0 but it is not going to be installed Depends: libcgal11v5 but it is not going to be installed Depends: libopenmpi1.10 but it is not going to be installed Depends: binutils-dev but it is not going to be installed Depends: flex but it is not going to be installed Depends: libopenmpi-dev but it is not going to be installed Depends: openmpi-bin but it is not going to be installed Depends: libcgal-dev but it is not going to be installed Depends: gnuplot Depends: gnuplot-x11 Recommends: paraviewopenfoam54 but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). rafal@nod I've read somewhere that it can be problem with free space on boot partition, so... there is an option to run parallel computing on slaves without installing OF on each of them? |
HPC Cluster Configuration Question | chuckb | Hardware | 1 | September 8, 2018 08:26 |
Problem with read and write files in DEFINE_ADJUST UDF on HPC cluster | tom634 | Fluent UDF and Scheme Programming | 0 | January 4, 2017 11:41 |
Problem with loading in paraview on hpc cluster reconstructedCase | Lorenzo92 | OpenFOAM Post-Processing | 0 | November 25, 2016 03:00 |
problem with User configuration | vetnav | OpenFOAM Installation | 1 | December 11, 2010 14:37 |
Cluster problem with dieselFoam (or whatever) | Rickard.Solsjo | OpenFOAM | 1 | August 6, 2010 08:53 |
