Weird Mesh with SnappyhexMesh
Old   February 20, 2020, 07:21
Default Weird Mesh with SnappyhexMesh
Julien
Elboy is on a distinguished road
Hi guys,
I've some trouble having a good mesh using SnappyHexMesh (i'm new to it). What i've tried is to create some refinement boxes ( 3 ) but the main problem is that the connexion between the boxes look weird. I've used ncells between levels to try correcting that but unsuccesfully.
Could you help me provide parameters or the origin of this issue ?
I've linked a picture of what it looks like.
Elboy is offline   Reply With Quote
Old   February 20, 2020, 07:38
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hi Julien,
I think your problem is not related to your mesh but only on the visualization.
I'm linking my answer from another post, let me know if it solves your issue:
Odd cell distortion when meshing a sphere in BlockMesh or SnappyHexMesh
Cheers,
Yann
Yann is online now   Reply With Quote
Old   February 20, 2020, 09:58
Julien
Thank you for the element you brought here. I've tried what you've explained in the link, the surface with edges seem far better however for vectors i still see some weird results as I can show you in the linked picture. I still dont understand ...
Old   February 21, 2020, 04:08
Yann
Hi Julien,
In ParaView, try plotting velocity at cells values instead of point values to see if there is really something wrong about the values at mesh transitions or if this is a graphical artifact.
Except for this, it's hard to help you without having more information about your case.
Yann
mesh 3d, snappyhexmesh cells
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 12:50
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] Failed 10 mesh checks after snappyHexMesh jet_engine OpenFOAM Meshing & Mesh Conversion 9 November 21, 2016 14:37
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 20:54
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
