Anyone know how to apply such equation in solver? |
Zhanyuan Wang
Rep Power: 8 ![]() |
The equation is shown in attached picture, which is a transport equation solving mass fraction Y, and alphal is liquid phase fraction defined in VOF solvers. Problem is that there are always many cells where 1 - alpha1 = 0, so if i simply write equation like:
(1 - alphal)*fvm::ddt(rhovg, Y) + (1 - alphal)*fvm: ![]() solver will break at the first time step because the value of (1 - alphal) is somewhere zero. Anyone know how to write the right equation? I will be VERY appreciated for any help offered ![]() Last edited by Zhanyuan Wang; January 7, 2020 at 04:20. |
Cyprien
Rep Power: 18 ![]() |
what if you divide your equation by (1-alphal) and that you have m/(1-alphal+SMALL) instead?
www.cypriensoulaine.com/openfoam |
Zhanyuan Wang
Thank you Cyprien!
I changed (1 - alphal) to (1 - alphal + SMALL) and then the solver will not break down, but regretfully i also didn't get the result i want. This equation aims to solver Y only in regions where alphal = 0, but result showed Y was still solved in regions where alphal = 1 and its value was unnormally big. I add a picture in my thread and you can see the result here. A droplet was put in the calculating area where alphal = 1 inside the droplet. So could you give me any suggestion on how to achieve my goal? Sorry to bother you so much time, but I m truly desperate for help... BTW, The equation can be find in following article, where the writter applied such equation in OpenFoam. http://scihub.bban.top/10.1615/atomizspr.2019027077 |
Cyprien
Why not using the Continuous Species Transfer formulation instead? It is fully compatible with the VOF approach (single-field equations instead of two-fields equations)
https://www.sciencedirect.com/scienc...21999119307302
Zhanyuan Wang
Thank you Cyprien for your kind advise!
I will read this article and hope it can help me solve my problem! |
#6 | |
Rep Power: 15 ![]() |
Hi Zhanyuan, Have you found a solution to your problem? |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Poisson equation in custom solver diverges for large boundary values | babakflame | OpenFOAM Running, Solving & CFD | 2 | May 23, 2017 20:11 |
Add Work due to body force in the energy equation for a lagrangian solver | mneben | OpenFOAM Programming & Development | 6 | January 19, 2016 05:30 |
Transport Equation for a scalar - Compressible Solver | alessio.nz | OpenFOAM Programming & Development | 5 | April 11, 2013 09:04 |
How to apply KINETIC rate equation on walls | SEEMI | FLUENT | 0 | August 28, 2008 08:07 |
