How to couple two solvers for simulation of two regions?
Old   December 11, 2019, 01:32
Default How to couple two solvers for simulation of two regions?
Long Jiang
jianglong is on a distinguished road
Dear all,
I am a new foamer here, using the OpenFOAM v6. Now, I am struggling to develop a coupled solver for simulating two regions simultaneously, where vector or scalar fields may exchange after each step on the boundary between two regions. (one solver could be interFoam and the other one for potential equations)
Here are two plans after several days learning of OpenFOAM:
1. Rewrite solver with reference to chtMultiRegionFoam. This solver is a multi-region solver although it is for heat transfer. I want it to be work for incompressible fluid as well, so I need to integrate two solvers mentioned into it. The problem is that it may not be so easy to implement after the day's effort. I have to deal with so many conflicts for source files there like createFields.H and so on. Another problem is about flexibility. I need to rewrite it again when I change the solver integrated.
2. Develop a method for communication of fields between two regions and run solvers for each region separately. I found a boundary condition called externalCoupled which may help. However, I am worried about computation efficient since it uses a plain text files to realize the fields exchange.
Can anyone have some good ideas for this situation?
jianglong is offline   Reply With Quote
Old   October 23, 2021, 16:21
Shah Akib Sarwar
Shah Akib Sarwar is on a distinguished road
Did you find any solution? I am also trying to couple two OpenFOAM solvers for my research.
Shah Akib Sarwar is offline   Reply With Quote
Old   October 24, 2021, 01:30
Ashutosh
night-hawk is on a distinguished road
Have you tried preCICE? here is link of there site https://precice.org .
night-hawk is offline   Reply With Quote
Old   October 24, 2021, 22:46
Tatsuya Shimizu
LongGe is on a distinguished road
Hello All
The OpenCFD-ESI version has such a feature. This tutorial will help you.
See: OpenFOAM-v2106/tutorials/multiphase/compressibleInterFoam/laminar/waterCooler
LongGe is offline   Reply With Quote
Old   November 4, 2021, 13:06
Shah Akib Sarwar
Hello all,
Thank you very much for your replies and I apologize for not responding earlier. I will look into both your suggestions and let you know when I have questions!
combination, coupled boundary, solver, two domains
[ANSYS Meshing] ICEM CFX Primitive Regions Appearing after Smoothing syble ANSYS Meshing & Geometry 1 July 29, 2016 17:29
chtMultiRegionFoam different properties in (fluid) region(s) volker1 OpenFOAM Pre-Processing 3 February 4, 2015 07:46
[snappyHexMesh] Using snappyHexMesh for multiple enclosed regions richard_vega OpenFOAM Meshing & Mesh Conversion 0 November 13, 2014 15:28
couple and spin index novice Siemens 6 July 8, 2004 04:31
couple problems leo Siemens 3 January 28, 2003 04:09
