Is it reasonable to use gradient limiter on pressure gradient?
Old   November 25, 2019, 08:12
Default Is it reasonable to use gradient limiter on pressure gradient?
Qiu Xiaoping
xpqiu is on a distinguished road
Should I limit the pressure gradient when doing steady incompressible simulation with low-quality volume mesh?In other words, can I set the default gradient scheme as
gradSchemes
default cellLimited Gauss linear 1;
In this page, https://bugs.openfoam.org/view.php?id=1410#c3246, Henry suggested that the pressure gradient should NEVER be limited. But I am not sure the reason behind it.
xpqiu
q.giskard@gmail.com
xpqiu is offline   Reply With Quote
Old   January 6, 2022, 06:38
Javier Vinuales
jvinuales is on a distinguished road
anyone has any comments about why not to limit pressure gradient?
jvinuales is offline   Reply With Quote
Old   January 14, 2022, 12:40
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
I don't see any reason for limiting the pressure gradient for steady state simulations. Especially if we use SIMPLE algorithm. The topic Henry is talking about was multiphase flows and transient ones (if I got it correctly). But I could not give you an answer to this one.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
gradient limiter, pressure gradient
UDF for zero pressure gradient at BC outlet ghordog Fluent UDF and Scheme Programming 1 April 28, 2022 06:12
What is difference between static pressure and gauge pressure? aja1345 FLUENT 1 July 20, 2018 21:05
negative pressure gradient in cone-shaped pipe Pawel Zdunek Lounge 0 April 29, 2017 16:16
Polyhedral mesh cyclic boundary problem C-L OpenFOAM 13 December 21, 2016 08:53
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
