Holes in mesh between transition levels
Old   November 15, 2019, 05:55
Default Holes in mesh between transition levels
ombretta bistoni
ombretta is on a distinguished road
I have a problem regarding a mesh. If I write in snappyHexMesh the same level of refinement (min and max):
level (6 6);
everything is fine (see first image). If otherwise I write:
level (5 6);
I have some holes between the transitions from level 5 to level 6 (see 2nd image).
Anyone knows why this happens? Is there a parameter of snappyHexMesh that I can change to solve this issue? I have tried a lot, but anything seems working. I attach the snappyHexMesh file.
Thanks for the help.
ombretta is offline   Reply With Quote
Old   March 9, 2021, 06:40
Default nRelaxIter
Wouter
wouterremmerie is on a distinguished road
we came across the same issue.
We haven't resolved it completely, but increasing nRelaxIter seems to reduce the bumps at the transition between levels.
Did you or anyone else find other settings that impact this?
wouterremmerie is offline   Reply With Quote
level of refinement, snappy hex mesh, transitions
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[GAMBIT] most efficient mesh for a combustor with holes perdita ANSYS Meshing & Geometry 2 November 17, 2010 05:48
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
