November 12, 2019, 18:04 |
file: unknown error
shach
Rep Power: 7 |
Hello Foamers,
I am facing a wired error as below. I was using chtMRSF with fvDOM radiation model. seems something wrong with the radiation model. However, I cannot find out where is wrong. Has anyone met this error? Thanks. Code:
Radiation solver iter: 0 Selecting boundary radiation Model: transparent Selecting boundary radiation Model: transparent Selecting boundary radiation Model: transparent Selecting boundary radiation Model: transparent Selecting boundary radiation Model: opaqueDiffusive Selecting boundary radiation Model: opaqueDiffusive Selecting boundary radiation Model: opaqueDiffusive Selecting boundary radiation Model: opaqueDiffusive Selecting boundary radiation Model: opaqueDiffusive --> FOAM FATAL IO ERROR: file: unknown FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::IOerror::abort() at ??:? #2 Foam::radiation::solidAbsorption::solidAbsorption(Foam::dictionary const&, Foam::polyPatch const&) at ??:? #3 Foam::radiation::wallAbsorptionEmissionModel::adddictionaryConstructorToTable<Foam::radiation::solidAbsorption>::New(Foam::dictionary const&, Foam::polyPatch const&) at ??:? #4 Foam::radiation::wallAbsorptionEmissionModel::New(Foam::dictionary const&, Foam::polyPatch const&) at ??:? #5 Foam::radiation::opaqueDiffusive::opaqueDiffusive(Foam::dictionary const&, Foam::polyPatch const&) at ??:? #6 Foam::radiation::boundaryRadiationPropertiesPatch::adddictionaryConstructorToTable<Foam::radiation::opaqueDiffusive>::New(Foam::dictionary const&, Foam::polyPatch const&) at ??:? #7 Foam::radiation::boundaryRadiationPropertiesPatch::New(Foam::dictionary const&, Foam::polyPatch const&) at ??:? #8 Foam::radiation::boundaryRadiationProperties::boundaryRadiationProperties(Foam::fvMesh const&) at ??:? #9 Foam::radiation::boundaryRadiationProperties const& Foam::MeshObject<Foam::fvMesh, Foam::GeometricMeshObject, Foam::radiation::boundaryRadiationProperties>::New<>(Foam::fvMesh const&) at ??:? #10 Foam::radiation::greyDiffusiveRadiationMixedFvPatchScalarField::updateCoeffs() at ??:? #11 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:? #12 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::Sp<double>(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #13 Foam::radiation::radiativeIntensityRay::correct() at ??:? #14 Foam::radiation::fvDOM::calculate() at ??:? #15 Foam::radiation::radiationModel::correct()^C |
December 6, 2020, 19:01 |
Alexey Ryakhovskiy
Rep Power: 12 |
Check if you have all the radiationProperties dictionaries for the neighboring solid regions.
If you have wallAbsorptionEmissionModel { type solidAbsorption; }; on a boundary in boundaryRadiationProperties than OpenFOAM will be looking for the neighboring region's radiation properties. |
November 7, 2021, 12:14 |
I am using laserDTRM Model as a heating radiation model ,It is showing unknown model.
DK
Rep Power: 5 |
--> FOAM FATAL IO ERROR: (openfoam-2012)
Unknown radiationModel type laserDTRM Valid radiationModel types : 6(P1 fvDOM none opaqueSolid solarLoad viewFactor) file: /home/dhar/OpenFOAM/dhar-v2012/run/heatTransfer/buoyantSimpleFoam/hotRadiationRoom/constant/radiationProperties at line 18 to 50. From static Foam::autoPtr<Foam::radiation::radiationModel> Foam::radiation::radiationModel::New(const volScalarField&) in file radiationModels/radiationModel/radiationModelNew.C at line 80. FOAM exiting |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 19:13 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
