Question about LES-PaSR combustion model with reactingFoam
Old   November 7, 2019, 08:43
Default Question about LES-PaSR combustion model with reactingFoam
XiangYang Liu
liuxy is on a distinguished road
I am new to Openfoam. I am simulating a simple jet (CH4) and coflow (air) problem (SandiaD in tutorial case) with PaSR turbulence combustion model. When I am using RAS model, jet is spreading and mixing well but when i tried to use LES model, jet is not spreading. Jet is going straight. no mixing is taking place and it is not looking LES from any angle. what would be the problem? what changes should be done to implement LES model in reactingFoam??
liuxy is offline   Reply With Quote
Old   November 7, 2019, 12:13
kai
zkth is on a distinguished road
Post your setting of combustionProperties and turbulenceProperties to get help pls.
Kai.
zkth is offline   Reply With Quote
Old   November 8, 2019, 00:41
XiangYang Liu
The attached zip file is the "combustionProperties", "turbulenceProperties" and the wrong distribution of CO2
Old   November 8, 2019, 10:30
kai
Not sure which version you are using. I use OF5,6,7. The PaSRCoeffs in combustionProperties is:
PaSRCoeffs
Cmix 0.03;
turbulentReaction true;//on;//yes;
//useReactionRate true;
Without turbulentReaction true, you assume laminar flame.
For turbulenceProperties, I have:
cubeRootVolCoeffs
deltaCoeff 1;
Hope this helps.
Kai.
Old   November 8, 2019, 10:32
kai
Btw, you are free to choose your own Cmix based on your requirement.
Kai.
Old   January 27, 2021, 06:09
Jiannan Liu
Southuno is on a distinguished road
Hi Liuxy, do you solve this problem?
The same situation I am that the LES model can't obtain reasonable results of Sandia D flame from RAS model.
Southuno is offline   Reply With Quote
Old   January 29, 2021, 18:02
Ran
random_ran is on a distinguished road
LES is cost. Usually required more denser grid. Have you tried finer mesh?
Yours in CFD,
Ran
random_ran is offline   Reply With Quote
Old   January 30, 2021, 21:04
Jiannan Liu
Same problem.
The methane jet does't spead, but i dont know if it is the problem of mesh resolution.
I will try this.
Old   February 1, 2021, 00:11
Ran
Okay, I will play with `SandiaD_LTS` at the same time.
Yours in CFD,
Ran
Old   February 4, 2021, 06:37
Jiannan Liu
Hi Ran,
The problem that methane doesn't spread is caused by lower SGS viscosity nut and lower turbulent thermal diffusion coefficient alphat. I compare these two values between RANS model case and LES case, and find that they are different by several orders of magnitude.
Hence, if you increase these two values by 10 times on EEqn.H and YEqn.H of reactingFoam, you would get similar results by LES model. But I dont know if it is a reasonable way to solve this problem, it just can get a better result.
Best
How to switch off combustion and reaction in reactingFoam shenzhou1987 OpenFOAM Running, Solving & CFD 16 October 26, 2017 16:31
partial premixed combustion model early combustion than expected omaradel FLUENT 0 June 27, 2017 15:38
Cs in the homogeneousDynSmagorinsky LES model allenfieldin OpenFOAM Running, Solving & CFD 1 August 5, 2015 00:10
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
