error in wallHeatTransferCoeff utility in openFoam 7
Old   November 7, 2019, 06:52
Post error in wallHeatTransferCoeff utility in openFoam 7
rohan majalekar
rohan1495 is on a distinguished road
I want heat transfer coefficient so by using wallHeatTransferCoeff I am trying to do that. But there is error
--> FOAM FATAL ERROR:
Unable to find incompressible turbulence model in the database
I tried this utility for openFoam default tutorials of all heat transfer solvers but there also same issue.
same error while calculating wallHeatFlux in conduction proble using laplacianFoam solver
Unable to find compressible turbulence model in the database
I have gone though almost every thread regarding this but didn't get any hint.
So anybody have idea about this???
Thank you..
rohan1495 is offline   Reply With Quote
Old   November 7, 2019, 07:41
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Dear Rohan and all others,
please read the following thread carefully before posting: How to give enough info to get help
@Rohan, actually you did not provide any information except the error message. Commonly, this snippet of information is too less. However, in your case it is easy:
yourSolver -postProcess -func yourFunc
By the way: If you don´t know google -> www.google.com
The result of your error message lead directly to the solution Unable to find incompressible turbulence model in the database
- wallHeatFlux with laminar flow
- https://cfd.direct/openfoam/user-gui...rocessing-cli/ (Section 6.2.3)
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
openfoam postprocessing, openfoam7
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 20:20
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
OpenFOAM Training Beijing 22-26 Aug 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 May 3, 2016 05:57
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
