Why i cannot monitor the velocity component residual |
王子阳
Rep Power: 7 ![]() |
i monitor the velocity in ControlDict ,the code is as folloes
#includeEtc "caseDicts/postProcessing/numerical/residuals.cfg" fields (p_rgh k alpha.water U); but the output residual.dat can't show the velocity residual the Ux residual shows the N/A what ie the reason? i need help thanks |
Rep Power: 8 ![]() |
can you post an example from the residual file please what it looks like?
Jan
Rep Power: 20 ![]() |
You can only plot residuals for velocities if you switch on momentum predictor.
velocity residual monitor |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
