Rep Power: 6 ![]() |
Hi Foamers,
I am trying to understand the PISO algorithm. I know taht is to work out the momentum equation and obtain the pressure. I am working with mhdFoam so is the PISO for this solver. The momentum equation in OF is the one for a single component of velocity ![]() ![]() ![]() In the solver they sum a divergence with a gradient, so I will close my eyes and think that this is only notation. Code:
{ /**********MOMENTUM*EQUATION**********/ fvVectorMatrix UEqn //:confused: ( fvm::ddt(U) //Time derivative. + fvm::div(phi, U) //Convection. - fvm::laplacian(nu, U) //Advection. + fvc::div(phiB, 2.0*DBU*B) //Lorentz force term 1. - fvc::grad(DBU*magSqr(B)) //Lorentz force term 2. );//DBU=1/(2*mu*rho), if (piso.momentumPredictor()) //Prediction of the velocity. { solve(UEqn == - fvc::grad(p) //Pressure term. ); } // --- Standard PISO loop starts. while (piso.correct()) { volScalarField rAU(1.0/UEqn.A()); //The matrix A^(-1) is saved as rAU. Scalar values at centres. surfaceScalarField rAUf //Scalar values at faces. ( "rAUf", fvc::interpolate(rAU) ); volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p)); //Evaluates relation A^(-1)*H and saves to HbyA. Vector values at centres. surfaceScalarField phiHbyA //Scalar values at faces. ( "phiHbyA", fvc::flux(HbyA) //Interpolation to faces and dot product with respective face normal vector + rAUf*fvc::ddtCorr(U, phi) //Correction related to the times scheme used to avoid an unwanted dependency on the time-step. ); constrainPressure(p, U, phiHbyA, rAUf); //Update the pressure BCs to ensure flux consistency. //Insure mass conservation by adjusting the in-coming and out-coming flux if the BC are ill-defined while (piso.correctNonOrthogonal()) //Non-orthogonal pressure corrector loop. { fvScalarMatrix pEqn //Pressure corrector ( fvm::laplacian(rAUf, p) == fvc::div(phiHbyA) ); pEqn.setReference(pRefCell, pRefValue);// pEqn.solve(); if (piso.finalNonOrthogonalIter()) { phi = phiHbyA - pEqn.flux(); } } #include "continuityErrs.H" //Including header file for continuity error evaluation U = HbyA - rAU*fvc::grad(p); //U has been calculated from p. U.correctBoundaryConditions();//The BCs do no longer correspond to the ones in 0/U. This function means that the BCs of U must be the ones precised in 0/U. //End of current time step } } ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now, in PISO loop is is splitted up the matrix ![]() ![]() ![]() ![]() ![]() ![]() So far everything is great, my problem is when some people apply the divergence on the previous equation (yes, on a array of scalars) and say that their divergence has to be zero to get ![]() The condition that must be met is ![]() i.e., ![]() ![]() ![]() not just ![]() My question is then what equation is OpenFoam solving: (1) or (2)? Last edited by rucky96; October 9, 2019 at 16:58. Reason: I was wrong placing the (2) |
Weiwen Zhao
Rep Power: 12 ![]() |
Hi rucky96,
Eq.1 in your post is wrong. Divergence should be applied to a vector field rather than each component of the vector field. |
Hi wwzhao, thanks for answering.
Of course neither me nor anyone can apply a divergence over a scalar. That is just the justification that some people use. They jump from the previous equation to ![]() ![]() ![]() Code:
fvScalarMatrix pEqn ( fvm::laplacian(rAUf, p) == fvc::div(phiHbyA) ); |
Weiwen Zhao
Hi rucky96,
If you replace \nabla with \nabla \cdot outside the parentheses in (1) and rewrite it in vectorial form, (1) is equivalent to (2). (2) is easy to calculate in Cartesian grids. However, OpenFOAM adopts unstructured polyhedral mesh. So the procedure for calculating divergence is a bit different from (2). |
mhdfoam, piso |
Development of PISO Algorithm | Roger9318 | Main CFD Forum | 1 | September 12, 2018 07:51 |
Eulerian multiphase model with PISO algorithm | Shehryar | Fluent Multiphase | 0 | July 6, 2017 02:13 |
Doubt Regarding the Predictor step in PISO algorithm | shadabdyn | OpenFOAM Programming & Development | 0 | February 12, 2017 01:41 |
Time step size sensitivity of piso algorithm | TypeR | OpenFOAM | 1 | February 1, 2017 16:00 |
Non-linearity Pressure Equation -- PISO algorithm | gdeneyer | OpenFOAM Programming & Development | 1 | August 23, 2012 05:19 |
