KOmegaSS Equations in OpenFOAM ?
Old   October 9, 2019, 13:22
Default KOmegaSS Equations in OpenFOAM ?
Os
losiola is on a distinguished road
Hello Guys ,
i am new to OpenFoam and i want to extract the KOmegaSST turbulence modele Equations implemented in the source code , i ve found the source code but yet i still cant ReadThe equations , Can anyone Please Guive me the exact Equations Written ( Mathematically )
Thank you
losiola is offline   Reply With Quote
Old   October 10, 2019, 02:50
Andreas P.
AndreasPe is on a distinguished road
In the kOmegaSST.H file, the papers of Menter are referenced, where the model is derived. Depending on the OpenFOAM version you are using, these could be a little bit different.
For example in v1906:
https://www.openfoam.com/documentati...8H_source.html
AndreasPe is offline   Reply With Quote
Old   October 10, 2019, 06:45
Os
Thank you for the replay ,
i ve already consulted the documentation and i found that there are dirrerent equations (some change in terms) and also in coefficients. i fully understood that but i want to try and get the equations out from the code and compare with that to be sure but unfortunatlly i have no programming background so if you can help me with that it gonna be awesome
Old   October 10, 2019, 09:55
Andreas P.
Maybe these training slides from last years OpenFOAM Workshop help:
https://sourceforge.net/projects/openfoam-extend/files/OpenFOAM_Workshops/OFW13_2018_Shanghai/Training/Implement-k-w-SST-model-and-its-derivation.pdf
Energy equations in OpenFoam Bloerb OpenFOAM Running, Solving & CFD 9 July 1, 2024 14:22
OPENFOAM for Aeroacoustics simulations (using Linearized Euler Equations) ms518 OpenFOAM 6 February 21, 2021 17:49
governing equations for 2D axisymmetrical problem in OpenFOAM openfoammaofnepo OpenFOAM 0 October 7, 2016 19:57
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 20:20
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
