initialising a thermal boundary layer at interface using funkySetFields
Old   October 8, 2019, 13:34
Default initialising a thermal boundary layer at interface using funkySetFields
Sam
saj216 is on a distinguished road
Hi all,
I am using interThermalPhaseChangeFoam to model a growing vapour bubble in a superheated liquid that can achieve results as shown in the following image.
Apologies for the enlarged image.
I have initialised the bubble using funkysetfields by using the following code.
initFieldAlpha
field alpha1;
expression "1";
keepPatches true;
initTemp
field T;
expression "378.15";
keepPatches true;
alpha1.org
field alpha1;
expression "0";
condition "pow(pos().x-0,2) + pow(pos().y-0,2) < pow((0.1E-3),2)";
keepPatches true;
BubbleTemp
field T;
expression "373.15";
keepPatches true;
However, I am trying to initialise a thermal layer around the interface of the bubble by the equation as shown in the image using the equation.
δT = r(T = Tsat + 0.99(T∞ −Tsat)) −R0
where δT is initial thermal layer thickness (7.00 × 10−6)
R0 is initial bubble radius
It is suggested that the initial thermal boundary layer is to be misplaced about 1-2 cells outside the bubble interface on the liquid side.
I am unsure whether this can be achieved by funkysetfields or groovyBC or through codeStream.
Thanks for spending the time looking at my problem. If i need to provide you with more information please let me know.
saj216 is offline   Reply With Quote
Old   October 25, 2019, 17:56
Sam
Hey guys,
Does anyone have any suggestions/guidance for this problem?
Old   November 12, 2019, 18:04
Sam
Anyone have any ideas, getting a bit desperate here . My knowledge so far, suggests that I use groovyBC however I'm unsure how to define the thickness of the boundary.
Old   January 10, 2023, 11:32
Nikhil Chitnavis
Nikhil2511 is on a distinguished road
Hi Sam,
Can you please tell me how you have initialized the temperature field (thermal boundary layer) in this pool boiling case. If possible can you share your test case?
Thank you
Nikhil2511 is offline   Reply With Quote
Old   January 10, 2023, 13:56
Sam
Hi Nikhil,
Apologises I haven't been able to complete this. My project changed and I ended up doing something else.
A way to do it is to initialise a space between the bubble and the liquid using the > and < commands.
So added another two set of commands for the alpha field and the temperature field for the area when the bubble is greater than the radius and when the interface is between the bubble and liquid.
I hope it makes sense to you.
Old   January 11, 2023, 03:45
Nikhil Chitnavis
Originally Posted by saj216 View Post
Hi Nikhil,
Hi Sam,
Thank you for the suggestion, I will try to implement this. Also in one of your page you posted that you converted interThermalPhaseChangeFoam for the newer version. If possible can you share that updated solver.
Thankyou
Old   February 10, 2023, 15:17
Sam
Apologies for the late reply.
I have found a link for interThermalPhaseChangeFoam for a updated version 6.
https://github.com/Swagga5aur/interThermalPhaseFoam
I hope this helps as mine differs greatly from the original solver.
Old   February 25, 2023, 12:05
Nikhil Chitnavis
Hi Sam,
Thankyou for your reply and suggestion for the updated version of interThermalPhaseChangeFoam.
boundaries, bubble, code stream, funkysetfields, groovybc
Fluid Domain moving with Rigid body Lloyd Sullivan CFX 3 August 17, 2018 10:58
How to use the CFX periodic interface zhihuawan CFX 61 January 15, 2018 17:20
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
