Is it ok to apply zerogradient boundary condition at the outlet for pressure?
Old   October 2, 2019, 03:48
Default Is it ok to apply zerogradient boundary condition at the outlet for pressure?
ijaz fazil
er_ijaz is on a distinguished road
I remember reading some notes, zerogradient boundary condition should not be applied at the outlet for pressure.
Outflow condition refers to zerogradient for all properties except pressure.
I'm analysing flow through a pipe in which half of the pipe is water while upper half of the pipe is air.
At the outlet of the pipe I'm concerned about fixing the pressure as the hydrostatic pressure of the water varies with height and since the density changes with two phase, I'm worried of fixing the pressure at the outlet.
Also in openfoam we need to fix p-rgh value and interfoam computes the pressure based on the height.
I noticed in two tutorials of openfoam v4.0 , p_rgh is set as zerogradient in the outlet. I'm also convenient to use zerogradient at the outlet, but my concern is the 'rule' pressure should not be 'zerogradient' at the outlet.
er_ijaz is offline   Reply With Quote
interfoam, interfoam hydrostatic, interfoam outlet p_rgh, multiphase
The method on dealing with velocity in static pressure outlet boundary condition mona.li CFX 2 September 30, 2017 02:33
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
How to set the Heat Flux boundary condition at Outlet creddy_trddc CFX 3 September 21, 2011 08:44
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
