Propeller tutorial problem in dynamicMeshDict origin |
September 30, 2019, 08:40 |
chandra shekhar pant
Rep Power: 17 |
Hello All,
For some weeks I am trying to run the propeller case by changing the geometry. I created a CAD geometry like, the propellerTip, innerCylinderSmall, innerCylinder and outerCylinder similar to that of tutorial, but could not run the simulations, since the simulations become unstable after 3x10^-5 and stops. I checked many online portals and found that the center of the CAD geometry should coincide with that of the center of origin of the rotation (described in dynamicMeshDict). I tried to put change the center of inertia to origin (0,0,0) but found an interesting fact that the geometry has the center of inertia (0,0,0) but if I convert it to the stl file the center of inertia changes. To do so I used meshlab, but meshlab translates the CAD model to the center of bounding box not at the global origin. I am not sure that which point has to coincide with the center of rotation described in dynamicMeshDict. I am so confused in this problem. I had attached the mesh/geometry and the report of checkMesh -allGeometry -allTopology herewith. Any help or suggestion in this regard is highly welcomed, since I have been struggling for weeks to make it work. Many Thanks! |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
foam-extend 4.0. Problem with wingMotion tutorial and sixDoFRigidBodyDisplacement | Bazinga | OpenFOAM | 0 | May 11, 2018 04:13 |
[OpenFOAM] Problem showing flow around propeller in Paraview | orkavic | ParaView | 1 | December 25, 2013 11:02 |
Tutorial Meshing Problem | gcam4 | FLUENT | 5 | October 27, 2012 14:29 |
Problem with the Fan tutorial | widedMed | OpenFOAM | 3 | March 29, 2011 04:35 |
