Finding wallShearStress in dbnsTurbFoam
Old   September 24, 2019, 01:54
Default Finding wallShearStress in dbnsTurbFoam
Bidesh Sengupta
BSengupta is on a distinguished road
Hallo Foamers!
I am using dbnsTurbFoam for my simulations. I need to find wallShearStress. I am trying to achieve it by two ways and failed in both.
Approach 1:
In controlDict:
functions
libs ("libfieldFunctionObjects.so");
tau
type wallShearStress;
executeControl writeTime;
writeControl writeTime;
Error:
-> FOAM FATAL ERROR:
Unknown function type wallShearStress
Valid functions are :
11
cellSource
faceSource
fieldAverage
fieldMinMax
maxFieldCell
minMaxField
probes
readFields
sets
surfaceInterpolateFields
surfaces
From function functionObject::New(const word& name, const Time&, const dictionary&)
in file db/functionObjects/functionObject/functionObject.C at line 94.
FOAM exiting
Approach 2:
After the simulation
dbnsTurbFoam -postProcess -func wallShearStress -latestTime
Error:
Usage: dbnsTurbFoam [-DebugSwitches key1=val1,key2=val2,...] [-DimensionedConstants key1=val1,key2=val2,...] [-InfoSwitches key1=val1,key2=val2,...] [-OptimisationSwitches key1=val1,key2=val2,...] [-Tolerances key1=val1,key2=val2,...] [-case dir] [-dumpControlSwitches] [-noFunctionObjects] [-parallel] [-help] [-doc] [-srcDoc]
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 0 found 1
Invalid option: -postProcess
Invalid option: -func
Invalid option: -latestTime
FOAM exiting
Can anyone kindly help me to find wallShearStress.
Thanks a lot for your time.
BSengupta is offline   Reply With Quote
Old   September 24, 2019, 12:52
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Which version have you used?
Edit: FOAM-extend 4.0 might not possess that FO unlike the other versions.
HPE is offline   Reply With Quote
Old   September 25, 2019, 06:28
Bidesh Sengupta
Yes, I am using Extend 4.
How to solve this issue in Extend 4, any idea?
Thank you.
Old   September 25, 2019, 06:50
HPE
HPE's Avatar
Take wallShearStress FO from either OF1906 or OF7, and compile it in extend.
Old   October 21, 2019, 22:17
Bidesh Sengupta
wallShearStress -compressible
This works..
dbnsturbfoam, foam extend 4.0, wallshearstress
wallGradU or wallShearStress on Time-Averaged Velocity Field minger OpenFOAM Post-Processing 6 November 7, 2019 06:30
Error computing wallShearStress with simpleFoam sita OpenFOAM Post-Processing 6 November 4, 2018 16:02
wallShearStress, wallGradU are inconsistent dancfd OpenFOAM Post-Processing 5 July 18, 2018 09:33
why does 'sample' do this? wallShearStress question CHARLES OpenFOAM Post-Processing 0 August 7, 2013 20:30
wallShearStress VS wallGradU bigrock OpenFOAM Post-Processing 0 July 2, 2013 06:54
