viewFactor radiation model stuck
Old   September 16, 2019, 19:14
Default viewFactor radiation model stuck
shach
shach934 is on a distinguished road
I am using chtMultiRegionSimpleFoam to solve a multiregion heat transfer problem. The surface2surface/viewFactor radiation model is employed. I tried without the radiation on, it works fine. When the radiation is turned on, faceAgglomerate and viewFactors are generated. About 30000 agglomerated surface is generated. However, when I started the simulation in parallel the model is stucked at loading viewFactor stage, like the following:
Selecting boundary radiation Model: opaqueDiffusive
Selecting boundary radiation Model: lookup
I tried with much less agglomerated surface ~5000 and single core. It works. The model is using several techniques, MRF, anisotropic material properties in cylinder coordinate system, volume heat source. Is 30000 faces a high number or I set something wrong? Any suggestion is high appreciated!
Thanks.
shach934 is offline   Reply With Quote
Old   May 25, 2021, 12:01
Jonas
JonL is on a distinguished road
Originally Posted by shach934 View Post
Thanks.
Hey shach,
so I realize I'm rather late to the party, but did you by any chance find a way to solve your issue? I am currently in a similar situation in which the simulation crashes after selecting each boundary radiation model and then simply crashes with a rather cryptic error regarding viewFactor and radiationModel, which I am uncertain on how to deal with.
Greetings,
Jonas
JonL is offline   Reply With Quote
stuck in simple evaporation model mossaied Main CFD Forum 0 November 21, 2018 15:21
simplifiedSiwek - error in calculating the position of a coal error guitar_love_15 OpenFOAM Running, Solving & CFD 0 November 4, 2018 05:06
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 10:29
Discrete Phase Model (bubbles stuck in an eddy) sahraaan FLUENT 0 September 8, 2011 01:32
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
