Error while running OpenFoam
Old   September 11, 2019, 17:08
Default Error while running OpenFoam
maryam shademani
shademani is on a distinguished road
Dear All,
I would be thankful if you could help me to know how to fix the error I faced in OpenFoam.
the error is as folowing:
FOAM FATAL ERROR:
[3] LHS and RHS of - have different dimensions
dimensions : [0 1 -2 0 0 0 0] - [1 -2 -2 0 0 0 0]
[3]
[3]
[3] From function Foam::dimensionSet Foam:perator-(const Foam::dimensionSet&, const Foam::dimensionSet&)
[0] in file dimensionSet/dimensionSet.C at line 521.
shademani is offline   Reply With Quote
Old   September 12, 2019, 04:47
Philipp Conen
pconen is on a distinguished road
Hey,
you have different dimensions!
Check out this.
CHT LHS/RHS Dimension Error
Greetings
Philipp Conen
pconen is offline   Reply With Quote
Old   September 12, 2019, 13:24
maryam shademani
Hi Philipp
thank you for your replying.
Do you know how can I find which parameter has a wrong dimension.Or which equation has been set wrongly?
Best
Shadi
Old   September 13, 2019, 06:04
Philipp Conen
Hey,
I am not sure. I would check out all documents in the 0-folder.
Greetings
Philipp Conen
Old   September 13, 2019, 09:11
anonymous
simrego is on a distinguished road
Hi!
I think the easiest way for that is finding a tutorial with the same solver, and compare the dimensions of your files in the 0 folder.
You have a wrong dimensions in your 0 folder for any fields. At least usually this is the reason for these errors.
simrego is offline   Reply With Quote
Old   September 13, 2019, 14:41
maryam shademani
Thank you Simrego,
I exactly used the dimension which are proposed in the solver.
Actually I am using two solvers, So that s why the dimensions are different.
I am interseted in coupling interFoam with immersed boundary.
Best
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 6, 2018 00:48
[Other] Basic questions about OpenFOAM cluster running and installing Fauster OpenFOAM Installation 0 May 25, 2018 16:00
OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. MBttR OpenFOAM Running, Solving & CFD 0 June 13, 2016 11:58
Difficulty running an inviscid compressible nozzle flow using OpenFOAM rbozinoski OpenFOAM Running, Solving & CFD 11 December 29, 2015 08:19
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
