August 21, 2019, 07:45 |
Cannot use Foam defined types in local class
Ashish Magar
Rep Power: 10 |
I am trying to build a class locally with interFoam. I tried to follow this example : How to add a new class locally However, the issues discussed were not resolved in that thread. I will paste the code here, and try to explain what are the difficulties. .H file Code:
#ifndef chnl_H #define chnl_H #include<list> namespace Foam{ class chnl { private: int chNo; Foam::labelList locProc; public: chnl(int a); int disp(); Foam::labelList getlocProc (Foam::labelList& gL); }; } Code:
#include "chnl.H" #include<list> //CONSTRUCTER Foam::chnl::chnl(int b) : chNo(b) {} int Foam::chnl::disp() { return chNo; } Foam::labelList Foam::chnl::getlocProc (Foam::labelList& gL) { locProc = gL; return locProc; } Code:
chnl.H:11:9: error: ‘labelList’ in namespace ‘Foam’ does not name a type Foam::labelList locProc; ^~~~~~~~~ chnl.H:17:9: error: ‘labelList’ in namespace ‘Foam’ does not name a type Foam::labelList getlocProc (Foam::labelList& gL); ^~~~~~~~~ chnl.C:10:7: error: ‘labelList’ in namespace ‘Foam’ does not name a type Foam::labelList Foam::chnl::getlocProc (Foam::labelList& gL) ^~~~~~~~~ Can anyone point out what am I missing here? Thanks |
August 21, 2019, 11:06 |
Adhiraj
Rep Power: 16 |
Did you include the appropriate OpenFOAM headers?
August 22, 2019, 02:05 |
[solved]
Ashish Magar
Rep Power: 10 |
Thanks a lot.
I thought using "Foam::type" would do the thing, but after your suggestion, I check Doxygen how they have used any class with "Foam::labelList". I found out I was missing Code:
#include "ListOps.H" #include "labelRange.H" Thanks. |
September 16, 2022, 04:33 |
#4 | |
Mostafa
Rep Power: 4 |
Hello ashishmagar600, could you help me I'm facing similar problem , however i tried to search for headers ,but all of them failed , when i implement the following code const volScalarField::GeometricBoundaryField& pbf = p.boundaryField(); i got the similar error does not name a type createFields.H:19:23: error: ‘GeometricBoundaryField’ in ‘Foam::volScalarField {aka class Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ does not name a type const volScalarField::GeometricBoundaryField& pbf = p.boundaryField(); |
class, foam namespace, types |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
