Problems with particle injection with zero velocity |
August 7, 2019, 11:47 |
Eduardo Cruz
Rep Power: 8 |
Hi everyone,
while using the icoUncoupledKinematicParcelFoam solver with injectionType patchInjection, I noticed some strange behaviour regarding particle initial velocity. Setting U0 to (0.0 0.0 0.0) in constant/kinematicCloudProperties had the same effect as initializing it as flow velocity. I'd like to know why this is happening and if it should happen. Regards, ECruz |
August 7, 2019, 21:02 |
Utkan Caliskan
Rep Power: 12 |
Colliding type parcels (DPMFoam and uncoupledKinematicParcelFoam) are not supposed to be injected with patchInjection as there might be a big overlap between particles initially which causes unrealistic behaviour. I believe setting inlet velocity to zero would make it even worse.
August 8, 2019, 09:26 |
Eduardo Cruz
Rep Power: 8 |
Even if I set collisionModel to none? The simulation is steady-state, by the way.
ECruz |
August 9, 2019, 22:39 |
Utkan Caliskan
Rep Power: 12 |
Without collisionModel it shouldn't be a problem. Could you share your kinematicCloudProperties file?
particle injection, patchinjection |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
FLUENT-DEM particle injection | Clarence91 | FLUENT | 0 | July 28, 2014 12:14 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
Check particle impaction with User Fortran | Julian K. | CFX | 3 | January 12, 2012 09:46 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
