[pimpleDyMFoam][dynamicMeshDict] "Attempt to return dictionary entry as a primitive"
Old   July 18, 2019, 02:07
Default [pimpleDyMFoam][dynamicMeshDict] "Attempt to return dictionary entry as a primitive"
Saurabh Das
Sorabh is on a distinguished road
I am trying to simulate a propeller in pimpleDyMFoam. Meshing has been successful, but on running the solver, the following error appears:
file: /home/mslab02/Saurabh/OpenFoamTutorials/incompressible/pimpleDyMFoam/TestPropeller2/constant/dynamicMeshDict.solver from line 26 to line 26.
    From function ITstream& primitiveEntry::stream() const
    in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 83.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::IOerror::abort() at ??:?
#2  Foam::dictionaryEntry::stream() const at ??:?
#3  Foam::motionSolver::New(Foam::polyMesh const&, Foam::IOdictionary const&) at ??:?
#4  Foam::motionSolver::New(Foam::polyMesh const&) at ??:?
#5  Foam::dynamicMotionSolverFvMesh::dynamicMotionSolverFvMesh(Foam::IOobject const&) at ??:?
#6  Foam::dynamicFvMesh::addIOobjectConstructorToTable<Foam::dynamicMotionSolverFvMesh>::New(Foam::IOobject const&) at ??:?
#7  Foam::dynamicFvMesh::New(Foam::IOobject const&) at ??:?
#8  ? at ??:?
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10  ? at ??:?
It seems like the issue is with the dynamicMeshDict, line 26. This is my dynamicMeshDict file:
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      dynamicMeshDict;
dynamicFvMesh   solidBodyMotionFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solidBodyMotionFvMeshCoeffs
    cellZone        propellerTip;
    solidBodyMotionFunction  rotatingMotion;
    rotatingMotionCoeffs
        origin      (0 0 0);
        axis        (0 1 0);
        omega       105; // rad/s //126 rad/sec == 1200 rpm
The line causing the trouble seems to be this one:
It would be a great help if someone could help me out with this problem.
Regards,
Sorabh
Sorabh is offline   Reply With Quote
Old   July 18, 2019, 08:23
CFD USER
CFD_10 is on a distinguished road
Which version of OpenFOAM you are using?
is it 3.0.x?
I think you are using an old dictionary version with a recent version of OpenFOAM.
CFD_10 is offline   Reply With Quote
Old   July 18, 2019, 08:24
Saurabh Das
is it 3.0.x?
I am using OpenFOAM 5.0
Old   July 18, 2019, 08:38
CFD USER
I think there is some changes in OpenFOAM 5 version. I think solidBodyMotionFvMesh is changed to solidBodyMotionFvMesh
Here is an example:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
dynamicFvMesh   dynamicMotionSolverFvMesh;
motionSolver    solidBody;
origin        (0 0 0);
axis          (0 1 0);
omega         105;
You can find other examples by executing the following:
find $FOAM_TUTORIALS -name 'dynamicMeshDict'
Old   July 19, 2019, 03:08
Saurabh Das
Well, I changed the syntax as instructed. This is the new dynamicMeshDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
motionSolverLibs ("libfvMotionSolvers.so");
cellZone        innerCylinderSmall;
origin      (0 0 0);
axis        (0 1 0);
omega       158; // rad/s
But the following error pops up:
keyword solver is undefined in dictionary "/home/mslab02/Saurabh/V15_V13_NoPorosity_ConcentratedSlurry_worked/constant/dynamicMeshDict"
Old   July 19, 2019, 07:57
CFD USER
Change your cellZone to propellerTip.
dynamic mesh, openfoam
No matching function error: Phase change source term added to interMixingFoam wavefunction OpenFOAM Programming & Development 2 February 4, 2022 08:46
driftFluxFoam viscosity model modification problem dleduc OpenFOAM Programming & Development 15 October 1, 2018 10:37
Creating a new field from terms of the turbulence model HaZe OpenFOAM Programming & Development 15 November 24, 2014 14:51
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
