TKE and epsilon in heat transfer model definition in reactingEulerFoam |
Gitesh
Rep Power: 16 ![]() |
I am adding a new heat transfer model at reactingEulerFoam/interfacialModels/heatTransferModels in OpenFOAM-dev. I have already done this before successfully in previous versions of OpenFOAM. I was using ‘pair_.continuous().turbulence().k()’ for TKE and ‘pair_.continuous().turbulence().epsilon()’ for epsilon for liquid phase turbulence properties. Now, in OF-dev version, if I try to use the same declarations then it gives some error like below: heatTransferModels/Coste/Coste.C: In member function ‘virtual Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::heatTransferModels::Coste::K(Foam::scalar) const’: heatTransferModels/Coste/Coste.C:85:41: error: ‘const class Foam: ![]() volScalarField k(pair_.continuous().turbulence().k()); ^ heatTransferModels/Coste/Coste.C:86:47: error: ‘const class Foam: ![]() volScalarField epsilon(pair_.continuous().turbulence().epsilon()) ; ^ I will be very thankful if someone can help in this issue! BR, GP |
How CFX calculate TKE and Epsilon from intensity? | David | CFX | 0 | November 24, 2005 04:53 |
