MO
Rep Power: 7 ![]() |
Hi all,
Hope you can help me to solve this problem. I am trying to do the simulation similar to the tutorial /opt/openfoam6/tutorials/multiphase/cavitatingFoam/LES/throttle3D. But I am using interPhaseChangeFoam solver. The attached figure shows the geometry and the boundary conditions. When I use RANS turbulence models, it doesn't have any problem at the outlet boundary. But when I use LES turbulence models, it will has negative Ux velocity at the outlet boundary. So I try to use non-reflecting BC at the outlet BC. Does anyone has the experience about the Non-reflecting BC (waveTransmissive)? I try to put the following part to the file U. But it gives me errors. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ outlet { type waveTransmissive; value uniform (0 0 0); gamma 1.4; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ RAS.png LES.png Geo.png |
Rep Power: 15 ![]() |
Well it is hard to diagnose a problem without seeing the error... that said, there are a few tutorials that use waveTransmissive for a pressure boundary condition (e.g. rhoPimpleFoam pitzDaily -- I think, I'd suggest performing the search yourself to confirm).
Caelan |
multiphase flow, non-reflecting bc |
Strange interPhaseChangeFoam behavior after restart | karamiag | OpenFOAM Bugs | 1 | December 29, 2016 12:16 |
Different implementation pEqn.H in pimpleFoam vs interPhaseChangeFoam | DanielRCalvete | OpenFOAM Programming & Development | 1 | December 4, 2015 10:37 |
Problem with INTERPHASECHANGEFOAM | shipman | OpenFOAM | 2 | March 26, 2014 12:36 |
InterPhaseChangeFoam ERROR | shipman | OpenFOAM Running, Solving & CFD | 37 | March 23, 2014 12:43 |
Bug about MULES::implicitSolve for interPhaseChangeFoam in OF-1.6 | chiven | OpenFOAM Bugs | 18 | April 18, 2013 22:56 |
