OpenFOAM & OceanWaves3D coupling
Old   June 18, 2019, 12:37
Default OpenFOAM & OceanWaves3D coupling
Marco Moretto
MMoretto is on a distinguished road
Hello all,
I am using the waves2Foam (r2131) combined with foam-extend-3.1 package to validate overtopping over rubble mound breakwaters. My first part is to validate the incoming surface elevation in front of the structure.
The incoming wave climate is generated with OceanWaves3D, by a steering.wmf file which is obtained from measurements in the laboratory.
To compare I placed wave gauges in the OpenFOAM domain (at the same position as during the measurements) as well as in the OceanWaves3D domain (same position as in the OpenFOAM domain and measurements).
Now comes the issue:
When I run a simulation where I change the startTime in the controlDict file to 1750 seconds (instead of 0s) from the total 1799 seconds to simulate, therefore only running OceanWaves3D, I get the wave signal represented at wave gauge 5 (red, which shows very good comparisons with the incoming measured signal in the laboratory generated with the same paddle file), see attached figure. When instead I start my controlDict file at 0 seconds, interFoam starts immediately and the signal measured in the OceanWaves3D domain is significantly different from the previously mentioned (blue line), therefore underpredicting the incoming measured signal.
So, when only running OceanWaves3D I obtain better results compared to measurements than when I am doing an OpenFOAM-OceanWaves3D simulation from the start, which is quite odd.
Is there something wrong with the coupling between OceanWaves3D and OpenFOAM or is this caused by other problems (which was done by Paulsen through waves2Foam)?
I would gladly hear some solutions!
If any information is missing, this is my first post so just contact me for extra required information to answer.
Regards,
Marco
MMoretto is offline   Reply With Quote
Old   July 13, 2019, 16:31
weiqiu
weiqiu is on a distinguished road
Hi Marco,
I am also working on the overtopping simulation, have you solved the problem?
Regards,
Weiqiu
weiqiu is offline   Reply With Quote
oceanwaves3d, openfoam, surfaceelevation, waves2foam
Coupling Openfoam and PyTorch scientium OpenFOAM Programming & Development 1 March 30, 2024 07:08
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
OpenFOAM for subsurface flow, or coupling with a subsurface flow code? chljl OpenFOAM Running, Solving & CFD 0 February 14, 2012 20:38
coupling OpenFOAM with other programs Martin123 OpenFOAM Running, Solving & CFD 3 June 3, 2009 19:13
