problem with combustion in chtMultiRegionFoam |
June 6, 2019, 13:10 |
Quentin BULARD
Rep Power: 7 |
I am working on the simulation of combustion inside an oven. I use chtMultiRegionFoam but I have problems trying to integrate the combustion into my fluid region. I took the same files and conditions as the SmallPoolFire3D tutorial. I find myself with this error: --> FOAM FATAL ERROR: request for volScalarField ph_rgh from objectRegistry Air failed available objects of type volScalarField are 123 ( aLambda_0 I10 a thermo:mu thermosi qem12 qin2 h I1 fres_CO2 CO2 qr0 qin9 Qdot G ILambda_2_0 qr2 qin10 qr dpdt O2_0 ILambda_1_0 I7 ILambda_11_0 alphat qin7 I3 qin15 CH4_0 qem9 qr7 qem13 wFuel p T I8 qem6 qem1 ILambda_13_0 qr10 fres_N2 H2O I14 ILambda_12_0 I12 I5 fres_H2O qr3 qem10 ILambda_7_0 ILambda_4_0 ILambda_5_0 I13 fres_O2 H2O_0 fres_CH4 qin qem5 I11 I15 ILambda_0_0 qem8 N2 nut qin11 K I4 qr14 ILambda_10_0 ILambda_3_0 K_0 CO2_0 ILambda_14_0 qr15 qr1 rho rAU k qin6 I9 h_0 qem2 I6 O2 p_rgh qem14 qin4 qin8 qr12 gh qem11 ILambda_8_0 CH4 I2 qem0 qin1 qr9 ILambda_15_0 qr13 rho_0 qem I0 qr5 qem4 qin13 qin14 qr11 qr6 ILambda_9_0 qr8 ILambda_6_0 bLambda_0 qin3 qem3 qem15 thermo:rho qem7 qin12 qr4 epsilon qin0 thermo:alpha qin5 ) From function const Type& Foam:bjectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>] in file /home/bulardq/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 193. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam:bjectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ??:? #3 Foam:rghTotalHydrostaticPressureFvPatchScalarFie ld::updateCoeffs() at ??:? #4 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:? #5 Foam::fv::EulerDdtScheme<double>::fvmDdt(Foam::Geo metricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #6 ? at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? Abandon (core dumped) bulardq@c-2014-074:~/Op Has anyone ever come across this problem? Can I try to integrate the combustion into chtMultiRegionFoam without having to recreate a new application? Thank you in advance for your answers. |
June 7, 2019, 04:34 |
Yann
Rep Power: 29 |
Hello Quentin,
As far as I know, combustion isn't implemented in chtMultiRegionFoam. Have a look at this thread : Can chtMultiRegionFoam do combustion, radiation and buoyancy? About your error, the interesting part is here : Code:
--> FOAM FATAL ERROR: request for volScalarField ph_rgh from objectRegistry Air failed Since you started from the smallPoolFire3D, the need for ph_rgh is probably related to the "prghTotalHydrostaticPressure" boundary condition for p_rgh. First thing is to check your boundary conditions to see if you have the appropriate "ph_rgh" file in the right directory. (or modify your boundary conditions accordingly) Yann |
June 7, 2019, 05:31 |
Quentin BULARD
Rep Power: 7 |
Hello Yann,
Thank you for your quick reply. My variable "ph_rgh" is in the good folder "0". At the level of my "p_rgh", "prghTotalHydrostaticPressure" is the boundary condition that I use. There may be some changes to be made in terms of fvSchemes or fvSolution? Quentin |
June 7, 2019, 08:36 |
Yann
Rep Power: 29 |
It's not easy to help you without more information.
The ph_rgh file should be located in 0/Air/ph_rgh or if running in parallel : processorN/Air/ph_rgh. Can you post a log file showing the error and if possible a minimal case with your setup and a run script to reproduce what you do? |
June 7, 2019, 09:36 |
Quentin BULARD
Rep Power: 7 |
June 7, 2019, 18:19 |
Rep Power: 15 |
Firefoam has a ph_rgh equation that's called as the silver spins up to computd a ph_rgh field that is then used by the accompanying boundary condition. If it is not computed (which it clearly is not here, hence the error), the boundary condition will return an error.
Caelan |
Problem using Partially-Premixed Combustion > G-Equation model | Daveo643 | FLUENT | 5 | May 27, 2021 03:00 |
Can chtMultiRegionFoam do combustion, radiation and buoyancy? | John1 | OpenFOAM Running, Solving & CFD | 5 | January 29, 2016 12:26 |
combustion problem | mcnair | CFX | 9 | March 22, 2011 15:06 |
combustion chamber problem | mcnair | ANSYS Meshing & Geometry | 0 | March 16, 2011 13:41 |
Combustion problem | rupal | CFX | 0 | April 21, 2008 06:29 |
