May 31, 2019, 01:24 |
Internal fan simulation
Rep Power: 12 |
Hi all,
I am trying to simulate a electronic cooling case which contains a small centrifugal fan. I first want to make the fan works before adding the electronic components. Since the inlet and the outlet shape of the fan are different, the fan BC which only works for cyclic patch does not work in this case. However the material that I can find from the tutorial and this forum are all about cyclic BC. Could anyone show me the correct procedure of doing this kind of simulation please? I have attached the picture of the fan. The red patch is the inlet and the green one is the outlet. Thank you |
June 2, 2019, 22:37 |
Rep Power: 12 |
Any response will be appreciated. Thank you
June 3, 2019, 05:10 |
Maybe fanPressure can help you out? I did not use this one myself, but it seems like it can do what you want? Regards, Tom |
June 8, 2019, 00:01 |
#4 | |
Rep Power: 12 |
Please correct me if I am wrong |
June 11, 2019, 04:30 |
Rep Power: 12 |
It is not 100% percent clear to me what you really want to achieve.
1) Do you want to model the fan by kind of actuator disk then no interfaces are needed: see http://www.tfd.chalmers.se/~hani/kur...ningReport.pdf 2) If you want to resolve your fan geometry by an MRF zone in steady or transient you need to use cyclicAMIs with interfaces at inlet/rotor rotor/outlet. For both variants you could use cyclicAMIs 3) Next, with it comes to interfaces, your AMI weighting factors should be near 1, so please make sure that your mesh is conform at the interfaces. 4) I recommend a "two/three-level" snappyHexMesh (or cfMesh) approach. Which means, first create the fan mesh within your rotating box. Next create a mesh for your farfield (volute or anything and or inlet). And merge those two meshes. Please make sure that you set the cellLevel discretization at the interfaces for all meshes the same. 5) Have a look at the TCFD CFD Support Tutorials. You do not need two use their software suite, but the basic OpenFOAM setup is a good starting point. |
fan, fan in hvac |
ducted fan simulation | Msvsraj | CFD Freelancers | 2 | July 25, 2019 16:18 |
Simulation of a flow of air in a room from a fan | tejas_jeurkar | FLUENT | 0 | April 4, 2019 12:41 |
Simulation of Radial Fan with simpleFoam MRF | nash | OpenFOAM Running, Solving & CFD | 2 | November 5, 2015 11:12 |
Fan Curve Model with CHT simulation | mariconeagles96 | CFX | 5 | April 22, 2015 02:31 |
Fan simulation divergence | ayothicfd | CFX | 18 | July 20, 2012 06:53 |
