OpenFOAM - three phase oil-water interceptor
Old   May 14, 2019, 03:41
Default OpenFOAM - three phase oil-water interceptor
foamF is on a distinguished road
Hi, I am doing a simulation of a three phase oil-water interceptor with OpenFOAM, using multiphaseInterFoam as the solver and kOmegaSST as the turbulence model.
The simulation runs normally until few to ten seconds (and the results look physically reasonable), then the model crashes. After many trials, I still could not figure out the problems. The model setup is simple with an inlet, 3 outlets, solid walls and symmetry plane (for cutting the object into a half).
For inlet, I used fixedValue for U and fixedFluxPressure for p_rgh. BCs for alpha.air, alpha.oil and alpha.water are 0, 0.5 and 0.5 respectively.
For the outlet at the top (for gas release), I used pressureInletOutletVelocity for U and totalPressure. The BCs for alpha.gas, alpha.oil and alpha.water were set to zeroGradient.
For the outlets at the bottom (for oil and water discharge), I used zeroGradient for all BCs.
I guess the BC setup should be fine. Any expert can give some advice on the possible issues and suggest some solutions.
Thanks in advance.
foamF is offline   Reply With Quote
Old   May 15, 2019, 05:12
BlnPhoenix is on a distinguished road
Did you try running it laminar first?
What exactly blows up during the run?
How's Co looking?
BlnPhoenix is offline   Reply With Quote
Old   May 15, 2019, 06:03
Thanks for your reply.
I am trying another run with the BC of the outlet at the top (for gas release) for passage of pure gas only. alpha.oil and alpha.water was set to fixedValue = 0 and alpha.air was set to inletOutlet. It appears to work now.
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
Simulation of dispersion of oil droplets in water -two issues milan.2012 CFX 8 April 12, 2018 19:38
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
Water Droplet in Oil Simulation cwl6750084 FLUENT 6 May 5, 2016 08:56
Simulation Water and Oil URGENT problem alexandrelp CFX 3 May 5, 2014 22:20
