May 2, 2019, 01:33 |
cyclicAMI jump in velocity across interface
Rho
Greetings!
Im using cyclicAMI to validate a paper which uses interfaces to merge non conformal mesh zones. Across the interface, I observe a jump in the velocity. Are there any settings within cyclicAMI which can be tweaked to solve this problem? I have attached an image of the velocity contours on which the mesh is superimposed and the have plotted the velocity jump across the interface. |
May 19, 2019, 23:06 |
moweijie
Rep Power: 7 |
Hi,Rho!
I am facing the similar problem. I am doing a case of pitching hydrofoil by AMI. When the internal mesh is rotating, the velocity of fluid is also rotating. It is not continued in the interface. I dont know how to solve it. Do you have any ideas? Thanks! |
May 22, 2019, 01:07 |
Rho
Hi Mowei,
Could you superimpose the mesh on the contour? In my experience, the magnitude of the jump can be reduced by ensuring that there is no abrupt change in the mesh on either side of the interface |
May 24, 2019, 03:00 |
moweijie
Rep Power: 7 |
Hi Rho,
Thank you for your reply! I have solved the problem. In the boundary files, I changed the 'transform' option from rotation to noOrdering. |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Total pressure jump at fluid-porous interface | toutnom | FLUENT | 4 | October 13, 2015 00:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
