forceCoeffs plot error
Old   April 29, 2019, 12:17
Default forceCoeffs plot error
Joe lee
Jinjolee is on a distinguished road
Hi Foamers, I used pimpleFoam to simulate an external flow, then I used the command:
foamMonitor ./postProcessing/forceCoeffs1/0/forceCoeffs.dat
to plot my coefficients.
However, while my coefficient looks fine inside forceCoeffs.dat and log.pimpleFoam, the plot looks absolutely different from the data.
Here is the plot:
It seems all the value lies on the line only at time 0.
May I know how to fix this?
In case you need the whole case, I uploaded to google drive:
https://drive.google.com/open?id=1EO...XIBP5iN33xp3rW
Thank you very much!!
Jinjolee is offline   Reply With Quote
Old   April 29, 2019, 13:52
mzzmrt is on a distinguished road
This is an axis scaling issue on the gnuplot script part.
Disable the auto scaling and use a manual one ranging for such as 0 < y < 1 for plotting...
mzzmrt is offline   Reply With Quote
Old   April 29, 2019, 15:02
Joe lee
May I know how to set the scaling?
I am just simply typing in
foamMontion /.postProcessing/forceCoeffs1/0/forceCoeffs.dat
I am not using any script, so I don't know how to regulate the scaling .. Thanks
Old   April 30, 2019, 07:58
I seems you are using a tool named foamMonitor and it uses gnuplot for drawing graphs automatically. I have no idea what foamMonitor is doing anyway so you have dig in the code.
Or you can directly import the *.dat file into any spreadsheet software and draw the graph manually.
Old   April 30, 2019, 13:42
Joe lee
Thank you. I think it will import it in spreadsheet then.
By the way, may I know if I have to use a script, how should I construct it? Is there any example coding? Thanks a lot!
Old   May 8, 2019, 10:39
This kind of scripting is easy. I guess this thread will help:
Tutorial of how to plot residuals !
Old   May 11, 2019, 12:59
Joe lee
Thanks a lot. I will look into it
forcecoeffs, graph, pimplefoam, plotting
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
