Trace yPlus along the airfoil cord
Old   April 29, 2019, 11:56
Default Trace yPlus along the airfoil cord
Os
losiola is on a distinguished road
Hello guys ,
I am making a 2 D airfoil simulation using pimpleFoam at the moment once the simulation completed i ve executed the following comand to calculate the Y+ Value
pimpleFoam -postProcess -func yPlus
and i got the yPlus values file in the PostProcess Directory .The Y+ values calculated and saved in the table are for different Time steps BUT me i want to Plot the Y+ values along the Airfoil Cord . How Can i Do that ? Or Is there another function That allows me to calculate the the Y+ values along the Aifoil (cord ) ?
ManyThankx
losiola is offline   Reply With Quote
Old   April 29, 2019, 14:47
mzzmrt is on a distinguished road
1. run paraFoam,
2. choose and plot the wing only on screen
3. filters > alphabetical > plot on intersection curves
4. choose the correct section direction
5. choose yPlus from tha dataset
mzzmrt is offline   Reply With Quote
Old   April 29, 2019, 16:19
Os
Thank you ve Much for your help and i Still Have one last question maybe you can help me with it?
I ve made a 2D airfoil simulation where Re=700 000 using the KOmega SST Turbulence Model and now i want to Plot the Eddy viscosity Ratio . Do you Know how Can i do It?!
Old   April 30, 2019, 07:54
You need to use the calculator tool in paraview.
If your case is incompressible eddy viscosity ratio means nut/nu so you can calculate and view it in paraview easily...
Old   April 30, 2019, 08:11
Os
Thank you very much for your help, It worked
Have a nice day
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 17:18
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 18:27
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
