April 29, 2019, 06:29 |
Flow does not go through the geometry
Hassam Rehmat
hello
I am new to openFoam and wanted to do simulation on a simple geometry with has a perforated wall between then inlet and outlet (picture attached). I did create the geometry in Ansys and convert it using fluent3DMeshToFoam and after it i created a thin wall using createBaffle because the internalwall was in faceZone. After running the simulation the flow does not go through the geometry. Any advise would be appreciated. |
April 30, 2019, 05:16 |
Robert
Rep Power: 12 |
I'd recommend creating the inner wall as an stl file and use snappyHexMesh.
If you liked my answer to your question, please consider leaving a "Like" in return |
Initialize flow from different geometry | B.Axel | FLUENT | 2 | January 24, 2018 14:15 |
Solving complex geometry with compressible flow | gfoam | FLUENT | 1 | May 19, 2017 15:56 |
[ICEM] ICEM CFD geometry creation and meshing flow over spheres | manuc | ANSYS Meshing & Geometry | 0 | April 18, 2016 13:09 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 09:17 |
Is an uniform flow possible for this geometry? | Michael Hu | FLUENT | 1 | April 13, 2006 23:11 |
