April 25, 2019, 10:28 |
cfmesh and buoyantSimpleFoam questions
Fab
Rep Power: 7 |
Hello everyone.
I'm very new to openfoam and I'm trying to use the buoyantSimpleFoam application. My first cases ran very well and I obtained reasonable results. I'm currently trying to use again cfmesh and buoyantSimpleFoam on another geometry but I have some troubles doing so. After a few iterations, my epsilon starts to blow up where there are sharp edges (see screenshot). Around sharp edges, the mesh (especially the BLs) becomes badly distorted and I think that is why epsilon blows up towards ridiculous values. So my questions are : - Is there a way to avoid BL distortion around sharp edges ? I used the surfaceFeatureEdges utility for my mesh. - Can I do something with buoyantSimpleFoam to stop epsilon from blowing up ? My first cases contained sharp edges and lots of 90° angles but everything went well. I used relaxation, first order discretization schemes and speed ramp up for the begining of the calculation. Any input will be greatly appreciated. Thanks. |
April 26, 2019, 04:03 |
Fab
Rep Power: 7 |
Hello everyone.
I finaly found my mistake. I hadn't changed the initialization value of the turbulent viscosity. I calculated the adequate values for k, epsilon and nut according to https://www.cfd-online.com/Wiki/Turb...ary_conditions and now my case is running smoothly. I didn't think the underestimation of nut by a factor ~50-100 would be enough to crash my simulation. |
