Boundary condition when moving wall without pressure dropse |
April 19, 2019, 05:31 |
Krzysztof
Goodmorning everyone,
I have a problem setting up the boundary conditions of my simulation. The simulation consists in representing the motion of the fluid between two parallel walls, one of which is moving at a fixed speed and the other is stationary. I'm trying to evaluate the effect that changes to the geometry of the two walls generate to the pressure profile. The problem arises because at the inlet and the outlet the pressure must be zero (relative pressure) and solving the simulation, stationary with incompressible fluid, generates a pressure difference (fictitious) to justify the motion of the fluid. The question then is how can the movement of the wall be defined as the unique cause of fluid motion and not a difference in pressure between inlet and outlet? I hope I was clear enough and I thank in advance anyone who wanted to help me. Sincerely Schaum |
September 7, 2021, 02:38 |
Michael Sukham
Rep Power: 6 |
I think if it is walls then giving a zeroGradient might solve the issue. In other words, the wall gives the back the same reaction of any force on it by the fluid. So i think zeroGradient should work fine.
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 05:59 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
