rubingqin
Rep Power: 7 ![]() |
when I use paraFoam, it will show this,I don't know why
Cannot find 'value' entry on patch ibCylinder of field U in file "/home/sjt/RUN/RUN/re=200/0/U" which is required to set the values of the generic patch field. (Actual type immersedBoundary) Please add the 'value' entry to the write function of the user-defined boundary-condition or link the boundary-condition into libfoamUtil.so file: /home/sjt/RUN/RUN/re=200/0/U::boundaryField::ibCylinder from line 25 to line 31. From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch&, const Field<Type>&, const dictionary&) in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 71. FOAM exiting Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed! |
openfoam dev |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
Cyclic patches in openFoam | AliE | OpenFOAM Running, Solving & CFD | 1 | April 13, 2018 09:18 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 36 | January 7, 2015 00:31 |
